M1078A1 "Pandora" Build | 2024-??? | ***Picture Heavy***
Ronmar
7,352
Port angeles wa
Over cooling is why I am guessing they incorporated the thermostatic bypass. When cold, it just doesn’t send any heat to the air/oil cooler.
the oil to coolant heat exchanger works both ways. On the A0, they sent all the bypass coolant to the heat exchanger. On a cool day, the engine will never get to full op temp until the transmission becomes a heat source/loaded. Below ~65F, The trans, via that cooler will absorb and dissipate all the heat an idling and moderately exhaust loaded engine will produce. Slightly elevated Idling in gear(cold wx warmup procedure), it still takes >10 minutes for the trans to turn from a heat sync to a heat source…
They fixed this “feature“ on the A1 trucks and kept the engine cooling system the way cat designed it(Bypass coolant sent back to engine block till properly warm). Probably a necessity for proper operation with ECU control…
InvictusDecretum
199
NC
Never heard of or seen a single report of that type of failure. Every one of these trucks I have dealt with has had amazingly clean coolant with little to no corrosion despite probably never being changed - My guess on this is that the cooling system being double the normal size (they basically sized it for a C15 - 15 liter engine) the coolant just naturally has more volume and thus the dissolved zinc anode and corrosion inhibitors don't get "used up" nearly as quickly as they would in other OEM applications with cast iron blocks. Thus the transmission heat exchangers (which are themselves very heavy duty all-metal fabricated units, not the plastic shite found in consumer and commercial applications) don't fail internally due to corrosion. I haven't seen any develop cracks or other issues and have not seen one report of such a failure either. It's not on my radar at all.
Makes sense. Thanks for the reassurance, I'll scratch it from my worry list which is already full enough. I only added it to my list to look into since have some lingering distrust of fluid to fluid coolers based on my 2.8L duramax "trans cooler" which was in the bottom 2" of the radiator and looked like this:
It sprung a serious leak from a unicorn part, a hard line press fit -> aluminum block that bolted to the trans the day before I was supposed to get married, and others have had issues with it leaking around the radiator fittings.
I much prefer to deal with AN or JIC fittings and hoses that can be repaired, remade, and are readily available at tons of places.
InvictusDecretum
199
NC
I am now the owner of the worlds most expensive thrust washer ! Once I'm done with the hydraulic system, I'll crack open my transmission to fix the valve body leak I probably caused, and see what the state of my C6 is... while making the swap to ATF, and hopefully not damaging any of the wiring in the brain of the transmission.
InvictusDecretum
199
NC
After 4 different re-designs
and 7 printed prototypes
I finally got the brackets ordered from Oshcut. I ordered them in .135" (10ga/just over 1/8") CorTen steel like shipping containers are made out of. Quite a bit of the truck is also made from CorTen steel and it's pretty ideal for being left outside all the time. I'm going to give the handpump and brackets a couple coats of Rust-Oleum 280107 Farm & Implement Enamel Paint, Low Gloss Black. I don't think I'm going to paint the box it mounts to since it's relatively rust free and I'd only be able to paint a small part of it right now. Plan is to paint that with the frame/cab/rest of truck.
Also made a little snorkel for the vent port, but going to cover the hydraulic pump anyway so it was really just an exercise in getting a circle to loft to a square in solidworks and make something printable. As soon as I confirm the dimensions after printing it in ASA (which shrinks more than PLA), I'll put it up on thingiverse or makerworld or somewhere others can download it if they'd like.
I'm so ready to get the physical brackets and actually install something instead of being stuck in a design->3d print OODA loop !
InvictusDecretum
199
NC
I've ordered quite a few things from oshcut, a number from corten as well. My generator is held on the truck with some of them.
Have a bambu x1c I've used to make various truck things. Working with solidworks as well.
They make printing so easy. Literally out of the box. It's crazy how much they closed the gap between a Stratasys (who is now sueing them) and a 3d printer from even 3yrs ago, even a markforge or similar.
InvictusDecretum
199
NC
Just a hint, oshcut takes .sldprt files directly, no need to convert them to dxf :)
Thanks for the tip ! I was trying to compare quotes between oshcut and sendcutsend (which only accepts dxf, step, stp, to my knowled) but... sendcutsend wouldn't recognize my bend lines so figured screw em haha.
InvictusDecretum
199
NC
Basically just waiting on those OshCut brackets to be delivered (FedEx says Monday !) and doing little things around the truck. This fitting was broken when I bought the truck but came right out with a medium size extractor from the ProjectFarm recommended IRWIN Screw Extractor, Spiral Flute, 6-Piece (53545).
Took a bit of experimenting to discover it was a 3/8NPT x 3/8NPT *flared* end. This is my first experience with that and I only had AN/JIC and regular NPT in my organizer.
