Sound deadening, sound proofing - which have you done and what are your results?
Pstyckiewicz
111
Massachusetts
So the carpet is called underfelt. It’s also called 4 way stretch. It is not to bad to work with. They use it a lot in camper van stuff. It is glued down. I used 3m spray glue. Spray the surface then spray the carpet and stick them together.
