Mep 831a black smoke won't rev up and shooting flames out the exhaust
Captainscall
60
Springfield IL
I would have sold you a known good injection pump for $30. Yanmar. Hope you got a good deal.
Forgive me if some of this has been suggested, but gears are turning...
The low pressure side getting air would make it starve for fuel. I have run them with a hose pressed on & air definitely getting in. With the electric pump on the MEP 831A, it will just leak vs pull in air. Easiest way to eliminate anything in the low pressure side is to remove the fuel inlet & gravity feed a fuel line from a funnel.
Are you sure the electric pump is moving the proper amount of fuel?
Did you try running it with the electronic speed controller linkage removed so it will just run at 3600RPM? How about something like 1300 RPM? And use the manual knob to stop it? Be sure to remember where it is at before loosening so you can put it back.
Did you confirm all the springs are present & on the linkage are where they belong on the governor? There are quite a few. TM will tell you the right holes to be in. This would all be behind the black knob area.
I had ordered a Chinese clone before I saw your post. If that fixes it I will definitely take you up on the offer. I appreciate it!! I hate throwing parts at this but not sure what else to do at this point.
I will definitely try the gravity feed just to eliminate air on the suction side of the pump.
I drained about 3 gallons of fuel using the pump. Just disconnected the low pressure line to the IP and put it in a can. It has really good flow.
It runs so bad that within a few seconds it has an error and disables the speed controller. I have manually ran the throttle linkage and it runs bad at all rpm.
I went and re watched all your series on the 831a hoping I have missed something but the issue I have appears to be different than anything you ran across in your videos.
Captainscall
60
Springfield IL
Years ago I had an issue with a Kubota 1.5l 3-cyl diesel genset. Those motors are legendarily indestructible. So it was missing and spitting and blowing diesel and would run OK then stutter..... After doing a bunch of fuel related stuff I finally pulled the unit off the mountain location and back to the shop for a tear down. It belonged to a bunch of hippy kids growing dope. Stuff is legal here and what do I care I don't smoke it I just fix stuff for a living.... Anyways I never did get a good story of what happened until I took it apart.
Turns out at some point the idiots had way overfilled it with oil. This bent one of the rods. Hydrolocked it. Just one of the three. Then they corrected the level before I got there. It was plain as day when I put the rods next to each other one was crooked as hell. Actually I could tell right away when I took the head off, rotated the motor, and you could see one of the pistons didn't rise as far as the others. I still have it kicking around the shop as a story piece. Guess those kids were smoking too much of their stuff while trying to do their PM's!
So I put a new rod in, then took the leads as spec, and it ran like new. If I was you I would go ahead and pull the head and squish some lead. Sounds like inadequate compression could be on the menu.
Thanks for the info. Once I finish checking the fuel side of things I definitely plan to year in to the motor if it is not fixed.
CallMeColt
1,589
Wilson County, Texas
Again, sorry if I repeated myself. I follow a bunch of threads & also have 3 different things going myself, but know the feeling when you just can't something.
I keep thinking it is a valve issue. The reason being, is these little engines are savages, and will attempt to run is the worst conditions. I think it combusting with the exhaust valve open.
In my videos for the MEP 831A, I was lucky that the engine itself had no problems. Just everything else was messed up.
I did have a Yanmar L100V that for the life of me, would not run right. I did everything. Time = money, & I finally gave up as the "v" models have slightly different parts, making them even more annoying to get. It ran fine at first, than for no reason acted like it was starving for fuel. Everything was replaced on it at some point in the injections system & compression test done. Finally, I just sold it to someone who wanted to take it on.
I've learned a lot more since then & I think my issue was valves. These little Yanmar engines are picky with the valve clearance. And even though they give a spec, I think that is to get you in the area. In my example above, I think it was a little tight, so it wasn't getting enough air.
In your case, messing with the valves is a really easy thing to do. Go a few steps on the gauge in each direction, start it, and see what it does. Can't be any worse than what you have now! When I rebuilt the L48 in the older videos, my valve adjustment was way off and it ran, but really bad. It looked like one of those old wind up toys that would try to do a backflip as it unwound. That also, needed to be slightly off-spec if I recall. At the time, I thought I just didn't know what I was doing. Maybe I still don't, but make things work?
Don't give up! I'm rooting for you.
Captainscall
60
Springfield IL
Thanks for all your help! I will not give up. I did check the valve clearances when I first got it. They were a little loose compared to the spec so I tightened them up to spec with no change in how it runs. Once I finish the fuel system I will tear into the engine if I have to. Just wish it was warmer out or I had a heated garage. It’s not fun working out there when it is 10 degrees but I will get this figured out eventually!!
My plan was to fix and sell this one to be able to buy an 802a or 803a at auction. My goal is to end up with an 803a which should be the perfect size to run my house.
DieselAddict
2,156
Efland, NC
Yes. The more I look at the machine it’s obvious Someone before me has definitely been in there before.
Ug, all bets are off then. You need to start from square one. The first thing I would do is pull the valve cover and check your valve action and timing.
