Intermittent check engine light at max speed/RPM
tuckerj84
10
Denver, CO
I could use some help diagnosing a persistent check engine light and power reduction.
2006 M1083 A1R C7
It started with an intermittent check engine light only at max speed/RPM. It seems like the ECM may have since derated itself, and while the check engine light no longer appears, there is significantly reduced power. The only code I can find has to do with boost pressure - 102.7.
  • I stated by checking the wastegate actuator. This seems to be function properly - VIDEO.
  • I then checked the operation of the wastegate on a test drive and it barely opens. VIDEO - you can barely see it move. Perhaps because it's derated???
  • Checked boost pressure. It's only producing about 13 psi. VIDEO
  • I haven't been able to locate any air leaks in the charged air cooler or associated tubing.
I'm leaning toward replacing the boost control valve. Does anyone know if this could partially fail? I would think it would work or not at all and it seems to be at least partially working.
Am I on the right track? Any other ideas?
GeneralDisorder
6,117
Portland, OR
The 3126 and C7 transducers always fail due to age. All of mine went out in the first year of me daily driving my 2008. Replace the boost pressure, atmospheric pressure, and oil pressure transducers. The boost pressure transducer in particular puts the ECM in limp mode. It won't add fuel because it can't trust the boost sensor - no fuel = no power = won't build boost. You should be seeing 26+ psi of boost.
Get your replacements from the CAT dealer ONLY. Aftermarket are usually crap and often don't work right out of the box.
And get a laptop with CAT ET. It's much more useful than a little gauge.
If you are interested in the 370 HP tune for that truck let me know.
And I *hope* you got rid of the XML's in your profile photo...... o_O
tuckerj84
10
Denver, CO
Thank you sir! A was looking for a problem rather than the addressing the sensors. Makes sense.
Do you have a good source to purchase CAT ET?
I need to chat with you soon about a 370hp tune as well. Just want to get this thing dialed in first.
tuckerj84
10
Denver, CO
That was parked, engine warm. Full throttle for a short duration.
It is consistent with driving though. I could take another one, but results are about 12-13psi max. Usually closer to 11psi average when driving.
Ronmar
8,306
Port angeles wa
Boost is usually dependent on load. Do a torque converter stall test. Second gear, stand on the brakes and add throttle. It should top out at the converter stall point ~ peak torque and full engine load. You don’t hold these too long as it really warms up the transmission fluid:) that should deliver max boost if the system is capable of it…
GeneralDisorder
6,117
Portland, OR
I'll send you a PM. You need manuals for that truck also.
GeneralDisorder
6,117
Portland, OR
The wastegate requires pressure to open and with computer control, you generally make the wastegate actuator about 1/3 of the max boost that you plan to run. That way when you do open the wastegate it responds very quickly, and if there's a problem you can drop the boost to "wastegate" level. Based on your readings the wastegate is likely around 1 bar (14.7 psi) - the wastegate varies somewhat depending on exhaust flow and back-pressure on the wastegate flapper. A really good turbocharger will exhibit about 2-3 times the boost pressure in the exhaust manifold before the turbine wheel so you have ~30 to 45 psi of pressure against the wastegate in addition to the actuator. Since the computer has seen a problem with boost pressure you are likely in a perpetual limp mode.......
Actually had this happen on my truck twice. It did clear the code on it's own both times. Once I pulled over and restarted and the other time I was in traffic and so the reduced power wasn't really causing a traffic jam so I just buried the throttle and when I eventually got to about 50 mph it cleared on it's own and the power came back. Has never happened again after replacing the boost transducer.
BUT I did have this happen to an A1P2 down at the base and in the case of that truck the boost pressure transducer had failed but not electrically. It was STUCK at zero psi after sitting for a couple years. The guys couldn't figure out what was up with it (no check engine light), and had done some fuel system and other services but the truck would not go over 10-15 mph. I noticed in CAT ET that the boost pressure was just zero, and oil pressure was stuck at 41 psi (engine off). So we replaced both. This didn't resolve the limp mode though - there was some derate code present and the ECM was absolutely pissed off and I never did figure out how to clear it. I ended up flashing that ECM to wipe it and that fixed the problem. So you might have put your ECM into a state where basically only someone with dealer level CAT ET with flashing capability can unlock it. I can do that but if you end up in that situation in the field the best solution is probably to carry a spare ECM since flashing the ECM is a process that most people aren't going to be doing. There may be some other way to clear that fault but I couldn't find it and haven't run across that a second time yet. It does sound like that's what you have going on though.
tuckerj84
10
Denver, CO
Got up to 23 psi using this method. I have the sensors on order and will start there.
tuckerj84
10
Denver, CO
Still fighting this one... I have some new info now that I have CAT ET. There are two persistent codes.
  1. 102-7 Boot Pressure not responding. This one will not let me clear it. It says it needs factory codes to remove (I believe this is what @GeneralDisorder referred to above). It is, I believe however, still occurring as I first noted it at 639 hours and it's still logging at 640 hours.
  2. 173-11 Very High Exhaust Temperature Derate. I was able to clear this and drove for about 15 min at what felt like full power. Boost was maxing out in CAT ET at about 28 PSI. Then the check engine light flashed briefly as it has in the past and I lost power. CAT ET is now reading about about 12 PSI max.
Please note I recently replaced the boost pressure transducer with a new CAT part. I can also see the boost pressure reading in CAT ET.
The exhaust temp doesn't make sense to me since, to my knowledge, the engine is not equipped with this sensor. Am I wrong here? CAT ET is telling me the Exhaust Gas Temp sensor is "unavailable" instead of "not installed" like some of the other sensor options.
I appreciate any input!
aw113sgte
1,401
La Crosse, WI
102-7, this is a very common issue when the linkage on the wastegate actuator is sticky. I had this and lubricated it with some white lithium grease I had on hand. Haven't had any issues since.
Moving the actuator manually you could really feel the resistance and how much better it was with the lubricant.
aw113sgte
1,401
La Crosse, WI
I did see this in another forum talking about the 173-11:
" The ECM calculates the engine exhaust gas temperature, by using the readings of the Inlet Manifold Temperature Sensor and the Atmospheric Pressure Sensor (along with a rpm factor). When the calculated engine exhaust gas temperature exceeds "predetermined limits", the engine will enter into a graduated (0% to 20%) power derate."
GeneralDisorder
6,117
Portland, OR
If that's the case then I would suspect the atmospheric pressure sensor. ALL the transducers are the same age and I would replace them all.
tuckerj84
10
Denver, CO
This is interesting. Thanks for the info.
I also have an issue with the Intake Air Heater I have yet to narrow down as well. Perhaps the low temp is throwing off the calculation for the Exhaust Gas Temp??? I wasn't thinking the two would be connected.
The Inlet Air Heater dash light comes on intermittently while the engine is cold. I recently replaced the relay since I found it had broken free from its rubber mounts and was bouncing on the back of the engine, but no change so I need to dig deeper into this one. Any thoughts on where to start?
GeneralDisorder
6,117
Portland, OR
The AIH should come on when it's cold outside, and yes once you start the truck the light can turn on and off a few times. That is typical operation in my experience. Once the ECM exits "cold mode" it will not use the AIH.
The AIH solenoid on the C7 is in a poor location. Water drips off the back of the cab and right onto the heater. I've run across some mention of AIH solenoid relocation kits that the military is using on some models or are available for some models. I'll have to see if I can find that again.......
tuckerj84
10
Denver, CO
Are you saying it's normal operation for the AIH dash light to be on while the AIH is operating? I wasn't thinking that was the case since it was flashing regularly last summer in 80 plus degree temps. I was assuming it was a problem light, am I incorrect?
Unfortunately, I cannot test that for a while as it's winter in Colorado, but I did notice in the status photo I took (and attached) yesterday the Intake Manifold Air Temp was 23 degrees (came as outside temp here) and this photo was taken after the engine was running for at least 30 min.
