In a word, small.
I kept it constrained to that size due to the roof sheet metal seam and not wanting to cut into that panel. It's also about as low as you can go on the bottom side of it too. It's awkward but possible to use, although our dog (not huge, around 40#) loves it and is quite happy to have it.
If I knew then what I know now, I'd do what's needed to make it a bit bigger. With its current configuration, I might be able to squeeze another inch or two out of it. Any more than that means cutting more metal.
It may be awkward, but it's definitely usable though. I've had the pleasure of driving away from camp in my slippers when it was cold/rainy/snowy/muddy outside. It is worth the effort.
My pass though is 20"wide, 30"tall. I'm 6'4" 200 lbs and can crawl through comfortably. I size it so I could crawl on my hands knees and not hit my back.I do wish I double stacked the filters as well. I would aim to put them all on one side with the expansion tank and dipsticks/fill tubes, leaving the space on the pass side to use freely. Totally should do that.
If you're going into the roofline, I'd keep it narrow-ish and use the remaining available space for a storage box or something. Getting to a door behind the seat(s) may be just as awkward. Maybe see what @aw113sgte has to say about his in practice?
I sure do miss being 200 lbs.... That was about 200 lbs agoMy pass though is 20"wide, 30"tall. I'm 6'4" 200 lbs and can crawl through comfortably. I size it so I could crawl on my hands knees and not hit my back.
Do I wish it were larger? Sure but unless it significantly taller I wouldn't be able to crouch through it anyways. So basically, I don't think I would change anything about it, because making it tall enough to crouch through is not feasible.
Cigarettes and Ozempic will fix that!I sure do miss being 200 lbs.... That was about 200 lbs ago
STRIPPERS AND A COUPLE 8 BALLS WILL TOO !Cigarettes and Ozempic will fix that!
That sounds like more fun than my idea!STRIPPERS AND A COUPLE 8 BALLS WILL TOO !
I ***DEFINITELY+++ would like that CAD. I just bought an M1088. I don't have it yet, waiting for the EUC . . . but I'm going to do the snorkle and air filter delete and use the Donaldsons. I'd love to get your design up in CAD and look at it!!!Anybody that wants the cad file for my design let me know.
Is there any reason we need two tubes for the Donaldson air filters? Would one larger tube with a Y at the top work?
So . . . if one arranges a larger tube, I'm thinking maybe a large rectangular tube, that goes vertically up the drivers side of the rear of the cab, one could plumb both Donaldsons into that rectangular tube. I'm thinking a tube strong enough to support the filters. Then lower down it would plumb into the 4 inch opening in the CAT. Hmm . . .I forget the actual dia of the intake piping upstream of the turbo inlet, but i'd assume you can just match that and be good. The two sides that I have merge into the same pipe at the base of the cab rear. Off memory, it's 4".
Pretty easy to see that bumping up the upper would leave "enough" space to stack them vertically. The only hurdle would be supporting it rigidly enough.
This pic also reminds me that I swapped the "AOH" pump system for a single circuit "H" pump because the only circuit I retained is the cab lift. Takes that control manifold and all the other crap out of the equation.
Sounds viable... Weld some platforms on it for mounting them and call it good.So . . . if one arranges a larger tube, I'm thinking maybe a large rectangular tube, that goes vertically up the drivers side of the rear of the cab, one could plumb both Donaldsons into that rectangular tube. I'm thinking a tube strong enough to support the filters. Then lower down it would plumb into the 4 inch opening in the CAT. Hmm . . .
Super easy:What was involved in deleting the control panel for the hydraulics? I've seen on YouTube that Nate Volk installed an electric hydraulic pump to lift the cab . . . What specifically did you do?
I have two of the filters as shown in the image up there with the y pipe. If that's the same kind that you're mentioning we only need one of then I'll sell my other oneYou don't need 2 filters. I used Donaldson D120037 on my C7. They have decent literature and this size is recommended for our flow volume.
