MTVR Manuals
Madball90
44
California
Did anyone find manuals for the MTVR, specifically the MK23? I have to pull the front differential and wanted to see if there were any pointers in there! Thanks!
There is only one Maintenance “manual” and it covers all variants of the MTVR. While in Iraq, we tried to upload the CD’s to the MEF share drive so that units could download load them. Something in the programs did not allow it to work.
Also, the newer EMS-NG does not work correctly all the time, especially when using the schematics.
I have been working on MTVR’s since 1999, first as a Marine then as a Oshkosh Truck Corporation FSR assigned to I MEF and II MEF from 2004-2009 and now I work on them for the Marines as a DOD employee.
I have yet to meet anyone who knows these trucks better than me….and yes I have current CD’s but no, I cannot upload them here.
aw113sgte
1,328
La Crosse, WI
Mine is a II MEF truck, 592080, any info on it?
1391MTVR
WI
@Madball90 you sound like you know your shit. Have a few questions regarding the CTIS on my 2002 MK23. When I change terrain to a "lower" selection; ie highway to cc, or cc to mss, I hear a audible "whine". Is this normal? I assume it's just the system purging the air from the tires? Next question, how long does it normally take to adjust pressures from different terrains/capacities? Seems like it takes mine a solid 10 mins before the lights go back solid. Perhaps I have a some sticking solenoids? Im not exactly sure where to look or start. I spent an enlistment around 7 tons, but never more that the occasional uncomfortable ride in the back. Bulk fuel Devil Dog here. Thanks for any and all advice you may have to offer. Rah!
aw113sgte
1,328
La Crosse, WI
"Whine" is not really descriptive. Air will release from the quick release valves. Yes the system can take a long time change pressure as these are high volume tires. Increasing pressure will take longer if revs are low as the compressor is spinning slower.
If the light eventually goes solid, that's a good indicator your ctis is working properly.
DeMilitarized
1,075
Gainesville, GA
Specifications say 20 minutes to fill the tires up from sand to highway is normal at idle.
dlynes
41
Augusta, Georgia
Do you have newer built tires? or just brave? I have not tried to air mine down as my build date tires are old. I believe btwn 1999 and 2007.
Madball90
44
California
The whining sound is kinda normal. That is the air being dumped out of the tires up to the quick release valves.
As per the IETM, if you try to air your tires up from Emergency to Highway it can take a total time of up to 40-45 minutes. So the 10 minutes you are saying yours is doing is within the norm for the MTVR’s.
I have been working on MTVR’s since 2003. First for Oshkosh (as a FSR in Iraq) and now for the Marines corps as a DOD civilian.
