Another Ahab
4,940
Alexandria, VA
i haven't used it since the 1970s .. i use good 'ol stinky fuel-oil as a penetrant and as a soak .. And yes i still have an old made-in-usa thumb-pump oil can with long flex spout for those hard-to-get-at precise targets .. I never run out of aerosol pressure this way :p
Good stuff! Yard sales here and there pop those old beauties up now and then. But hard to find for sure now with the world done all gone to plastic like it has.
There's also a shop in Nevada that sells old European military surplus, and they have product like that also now and then (usually old Czech or Swiss surplus).
Deutsche Optik I think is what they're called.
msgjd
4,096
upstate ny
New cable arrived and it's a very good quality cable from the feel of it.
Does anyone here recommend lubing the cable up with cable lube before installing it? Doesn't seem like it has that much lube on it from the factory...
for a long time i have done it to brake cables (civilian & mil) and hydraulic valve cables on heavy equip by stuffing one end into a funnel throat and sealing the joint with a piece of old innertube and hose clamps (rubber hose would work) .. Hang it up and pour bar & chain oil .. It can take minutes to an hour or a day for the "molasses" to start running out the other end, depends on temperature, length, and internal clearance .. It helps to manipulate (or twist if it will twist) the internal cable from time to time.. My neighbor uses gear oil , but i want oil that will literally "stick"
If a cable jacket is steel (no rubber) , I then dip it in a pan of oil before installation.. Yep, it's messy, but i have never had to mess with them again.. Luckily, most hyd valve cables for heavy equip have grease fittings on each end , something i wish was done on parking brake cables
msgjd
4,096
upstate ny
Had a little helper this time!
Little Soldier-B's can stand up and reach places the rest of us can't ! .. Perfect for those catch-22 spots where we can't reach laying down and can't see it squatting or kneeling..
I have one of mine all this week and yep he's gonna get dirty ! :D
(his gramma and mom ain't gonna see him before he hits the tub rofl )
jaws4518
Cold Beer
227
123
Abilene, Texas
Not this week but last year.:D M931-A1 cab rehab. Actually, going over the entire truck to make ready for hauling. Putting in a back wall mount R-2400-0 RD-2-4369-1 OEM Red Dot Backwall unit. This is the Space X truck posted as my user pic. It is a very nice tractor but it needs a complete going through. I actually drove it home from 200 miles away. Looking back, I am really surprised we made it back without any issues.
US6x4
2,508
Wenatchee, WA
I've had the door weatherstrip pieces laying around for several years and finally got around to putting them on. Driver door required wire wheel, rust converter, primer, and paint before gluing them on. The only glue they had was 3M yellow...wish I had held out for black.
Another Ahab
4,940
Alexandria, VA
Looks like it needs some work, sure; but overall really solid!
What all are you planning on hauling, jaws4518?
:driver::beer::driver:
US6x4
2,508
Wenatchee, WA
I designed and laser cut a pair of battery hold downs out of 10 gauge stainless to work with the 8Ds that I have and just installed them. They look pretty good and will work as long as the rubber terminal covers don't disintegrate. I reversed the j-bolts so that they would be positioned further inboard so that the bolt tabs could extend to the sides instead extending over the front and back (when facing the battery boxes).
TechnoWeenie
1,803
Nova Laboratories, WA
I bet there are a ton of people who would be interested in those.
US6x4
2,508
Wenatchee, WA
You bet - and I can make as many as they want! Not sure what they would cost as I haven't seen my own shop bill yet, but these are pretty slick.
I'll post back with dimensions tomorrow when I have my computer handy. Most 8Ds are roughly the same size but the post centerline and distance from the post to the edge can vary.
US6x4
2,508
Wenatchee, WA
The flange IDs of the battery hold downs is 10.957" x 19.488" so folks can measure their battery tops to see if that will fit. These could be made out of carbon steel instead of stainless and could even be made out of 12 ga. steel instead of 10 ga, but I do like the stoutness of the 10 ga.
Before I make any more I think I will increase the clearance around the posts.
US6x4
2,508
Wenatchee, WA
Currently attending the Cashmere, WA Memorial Day ceremony. Very patriotic town with a high concentration of little flags next to the grave stones. Every year they put on a very well tuned service complete with 21 gun salute, a fly-over, and, of course, reading of the extensive list of names of the veterans from Cashmere.
This is just one corner of the cemetery.
msgjd
4,096
upstate ny
spent memorial day (monday) moving composted cow & horse manure to someone's large garden and spreading it out.. 6 loads heaped to the top of the cab protector .. although very damp and packy, the stuff was lighter than expected
Ground still too wet to get the loader into the pile thus tracks did the trick . . Picture taken prior the making of a mess ;)
msgjd
4,096
upstate ny
.... and this morning (tuesday 27may) was past-due time to take care of a couple things on the M817
First task: Connie says check for the fan bracket bolt/washer/spacer upgrade ... OK, the OMS shop beat me to it (y)
Second task ; disable the cooling fan's time-delay relay per TM2320-260-20 para 3-52 , see below ---
Note to self: tightening fan belts automatically disables the time-delay relay on the fan (y):LOL:
Note to self: don't forget the knee pads next time :cautious:
