MEP-805B Magnetic Speed Pickup (MSP) Missing.
dpTrail
Houston / Texas
I bought MEP-805B on GovPlanet and after spending lot of time trying to start up discovered the MPS is missing. I found an MSP on Green Mountain for MEP-805B which showed the MPN to be a GAC MSP6728. When I found EBAY and went to order it says the thread is 5/8-18 but when I checked the hole is much bigger. Tried to measure and looks like maybe 3/4-16. Is there sopposed to be some kind of adapter on flywheel housing to use 5/8-18 MSP?
Guyfang
26,721
Burgkunstadt, Germany
No. There is no adapter. Perhaps you should download the TM's for the MEP-805B.
MSP675C is the Part Number I see in the parts manual.
dpTrail
Houston / Texas
Thanks for the information on TM's link. Looking at MSP675C it appears to also be 5/8-18 thread. I am going to look at getting a thread insert to reduce the 3/4-16 to 5/8-18 to make it work hopefully.
2Pbfeet
1,407
Mt. Hamilton, CA
If it were me, I would try a 5/8-18 bolt before going too much farther. I can't count the number of times I was sure that I had eyeballed the size of a bolt, only to be off.
Is an MSP675C a compact version of an MSP675?
All the best,
2Pbfeet
Guyfang
26,721
You all are missing something here. The Army doesn't buy gen sets that all are not 100% the same. The TM gives you the right number for the MPU. That's what goes in the set. So if its the wrong size, how can that be.
So I went back into some old files. The part number MSP6728 is a sub number, that needs a reducer ring to fit. I have never seen one. So I guess it never was used often. There was a great shortage of MPU's for a few years.
This part number and NSN are the right size.
MSP6735​
0BXW5​
2815-01-499-1057​
dpTrail
Houston / Texas
Thanks Guyfang. I found an old thread MEP-805B - no power to the ADC100 Electric Actuator where someone had same issue and 155MM suggested that the KenWorth MPU was a direct fit for 805B including same connector. He posted part number Q21-6005RT and specs attached.
I ordered one from Raney's in this link Q21-6005RT Good price with long connector whip. Hopefully will be plug and play. Will update after I receive.
dpTrail
Houston / Texas
I have received and installed Q21-6005RT MPU. Note first that the connector is wrong and had to be cut off. I simply used a touch safe terminal block and ferrule crimped wires to hook up. I ran the AC volt check with just cranking the motor and got 0 Vac on first check. Good thing I read post about threads not allowing to insert all way down to flywheel. Tried a tap but the taper bottoms out before threads cleaned up so just followed with 3/4-16 bolt and WD-40 and ran it down in out till sure I was contacting the flywheel. To make sure I was getting the MPU all way in, I ran bolt all way down and mark top thread exposed. I then positioned the jam nut of MPU with same thread length of bolt. This was helpful because installing MPU it was hanging up a few time short of bottoming.
Ran AC Volt check again cranking and showed 0.57 VAC. This is a lot lower than 2.5 VAC others said should be seen. Also watching the Speed Sensor LED on the Speed Controler could not see it flashing at all when cranking.
I was concerned but ultimately just decided to give it a try. It pretty much fired right up and works just fine. Note the Speed Sensor LED still doesn't flash at all. I suspect this is due to Low 0.6 Vac output. It ultimately is a counter and is still sufficient to operate the Speed Controller.
Even though I am using this MPU I would recommend getting the GAC MSP6735. After the fact I did get quote from GAC Dealer - Carson Engine & Supply in Dallas TX for $88.19 with connector for Plug and Play.
2Pbfeet
1,407
Mt. Hamilton, CA
I'm glad that you made it work.
FWIW: If you ever want a tap with a full diameter thread that that goes (nearly) to the tip/bottom, look for a tap with a bottoming chamfer, or a "bottoming tap". They are designed for things like blind holes, and ones with low end clearance. They need some precut threads to start them, and it is important to take it slow and easy because they cut the full thread more less at once.
All the best,
2Pbfeet
dpTrail
Houston / Texas
All the best,
2Pbfeet
Thanks, it was just quicker and cheaper for me to get a $3 3/4-16 Bolt block away from shop.
