Ignition Lock Cylinder Replacement
HelluvaEngineer
89
Atlanta, GA
I am replacing some parts in my M1009 steering column and while I'm in there I wanted to replace the lock cylinder to one that doesn't have the universal CUCV key.
Also, I pretty much have to now as the face of it just broke off as I was trying to remove it.
What is the trick to get it to release? It looks like on my 1984 it's the style where it has a tab in the back that you are supposed to depress.
In a related note, I just realized that the replacement I bought is the standard type where there is a pin that goes through a hole to retain the lock and then a screw over the top to retain that.
Is it possible to convert it to that style?
I will add some attachments to provide context.
Thanks in advance.
signal-2025-04-24-174115_002.jpegsignal-2025-04-24-174115_004.jpegsignal-2025-04-24-174115_003.jpeg
WWRD99
1,898
York Pa
Looks like you took the bolt out that holds it in . Pop the key in and turn it to run and it'll pull out.
HelluvaEngineer
89
Atlanta, GA
There was nothing in that hole. In my case I think this is the older 70's style release that is farther back.
Honestly if I don't figure this out in the next couple of days I'm gonna jam a small screwdriver in the back slot and liberally apply the slide hammer.
WWRD99
1,898
York Pa
Ok did you turn the key to run and pull on it?
HelluvaEngineer
89
Atlanta, GA
Yes, absolutely. That's when the cheapo cast cover broke off. What I'm trying to explain is that I think there were two versions of the lock cylinder. Some if the 84's apparently have this style. I do not have the pin nor the cover screw that most of them have.
WWRD99
1,898
York Pa
Well I got nothing for ya then. I've rebuilt dozens of these straight columns and tilt ones and never had a problem pulling them out. You shouldn't pull on that cover just pull on the key wiggling it around to get it to release.
HelluvaEngineer
89
Atlanta, GA
I've found that most of the M1009 owners have the newer models with the forward radio mounts. Unfortunately, mine seems to be a very early one. Apparently I got some leftover parts.
WWRD99
1,898
York Pa
Ohhh now I see where you're at. There's a slot that you can pop a pocket screw driver in and push in the lock retainer. That's odd that is in that truck. I think you can use the new style with the bolt but not sure. Might be easier to get the older style.
HelluvaEngineer
89
Atlanta, GA
Thanks all for the feedback. I want to save something here. I think ChatGPT hit a home run. For our non-tilt steering wheels, it appears that GM P/N 7830377 should be the correct retaining pin, with no spring required. I'm going to pull out the old one, use the new style, and hopefully this pin will just thread in.
87cr250r
2,104
Rodeo, Ca
I did a lock cylinder in my 1976 truck some years back. There is a thin spot in the column casting that you hammer a screwdriver through to get access to push the spring loaded retaining pin.
HelluvaEngineer
89
Atlanta, GA
Thanks again to everyone. I was just able to pull the lock and install the new one. In my case, I used a narrow flathead in the slot on the top left while jiggling the key and it walked right out. Now I'm just waiting on the 7830377 screw to arrive from the Ebay vendor and I can put everything back together.
