- 8,212
- 20,760
- Charlotte NC
.Thank You Mullaney. You have been a big help.
š»
Glad I could help - and speak up if you run across other things that need to be talked out!
š»
The brake system needs looking into. Right front has fluid in wheel well in bottom and only after one drive. I added around a third of what I added after I got Her. Also bottom of master cylinder has fluid on it. Boot in front where plunger is looks good and not blown up in size.Front wheel boots look good I think. Is one moving out of position ( one showing zipper ?
And oil pan needs to be cleaned. Looks like a mix of road dirt road oil and oil from truck. Not dripping engine oil. Will clean off this paste like mess.
Thanks
Iād recommend you not worry about adding any more brake fluid until you fix the leak. Personally, I wonāt drive my trucks with leaking brakes. I had a sudden complete brake failure because I didnāt fully understand the brake system. Your call, regardless the brakes need a full inspection and repair as necessary. The #1 reason any of my brakes leak is because the cylinder seals have failed. I have extra parts to rebuild my wheel cylinders for my 4 M35ās on hand always. Best way to figure out the issue to jack up the offending wheel(s), remove said wheel(s) and remove the brake drum. Be very particular about following all steps in the technical manual, in this case I believe it is TM 9-2320-209-20. That TM was rereleased as TM 9-2320-361-20. I recommend you use the 361-20 as Iāve found it much easier to follow. TM 9-2320-209-20P is where youāll find the various part numbers, with which you can order new parts from several internet suppliers and vendors on this website. The first time working on any new type brakes has always been a pain for me. It always takes at least twice as long to work on the first brake drum/cylinder/hoses as any subsequent repairs. I donāt recall if you said which brake fluid you use. I only use DOT 5 brake fluid. My wheel cylinders last far longer than ones in which DOT 3 has been used. If there is a possibility that you have mixed types of fluid, again, I donāt recommend you drive your truck until she is fully up to snuff. If you have mixed fluid, youāll need to go through all of your brakes before any really strenuous driving. If you donāt already have one, purchase or maybe borrow a brake bleeding device and only use it on the one truck.The brake system needs looking into. Right front has fluid in wheel well in bottom and only after one drive. I added around a third of what I added after I got Her. Also bottom of master cylinder has fluid on it. Boot in front where plunger is looks good and not blown up in size.
Plan to drive it tomorrow farther than the first/ nice easy drive I hope. Maybe getting to 40-45 mph.
Thanks
Thank You. You are SO Correct. I will be checking into the leak at master. May be a loose line or:: but I know the fluid on wheel well probably means bad wheel cylinder seal.Iād recommend you not worry about adding any more brake fluid until you fix the leak. Personally, I wonāt drive my trucks with leaking brakes. I had a sudden complete brake failure because I didnāt fully understand the brake system. Your call, regardless the brakes need a full inspection and repair as necessary. The #1 reason any of my brakes leak is because the cylinder seals have failed. I have extra parts to rebuild my wheel cylinders for my 4 M35ās on hand always. Best way to figure out the issue to jack up the offending wheel(s), remove said wheel(s) and remove the brake drum. Be very particular about following all steps in the technical manual, in this case I believe it is TM 9-2320-209-20. That TM was rereleased as TM 9-2320-361-20. I recommend you use the 361-20 as Iāve found it much easier to follow. TM 9-2320-209-20P is where youāll find the various part numbers, with which you can order new parts from several internet suppliers and vendors on this website. The first time working on any new type brakes has always been a pain for me. It always takes at least twice as long to work on the first brake drum/cylinder/hoses as any subsequent repairs. I donāt recall if you said which brake fluid you use. I only use DOT 5 brake fluid. My wheel cylinders last far longer than ones in which DOT 3 has been used. If there is a possibility that you have mixed types of fluid, again, I donāt recommend you drive your truck until she is fully up to snuff. If you have mixed fluid, youāll need to go through all of your brakes before any really strenuous driving. If you donāt already have one, purchase or maybe borrow a brake bleeding device and only use it on the one truck.
Thatās it for now.
Good luck and keep me posted.
.I have done car and pickup drum and disk brakes. Nothing of this size. I will be looking into the leak at the Master. And the front wheel where the leak is has got to be worked on. Probably in time all the wheel seals need changing. Truck 42 yrs old. The drivers front side where the new zipper boot is may be the only wheel I sorta feel like seals OK. Thank you for saving me from my ( I canāt wait to see what she can do self) I have been a long time machinist till I retired. Commercial and Military parts.
Thanks: biscuitwhisler37 : Mullaney and jeffhuey1n
Question :: after the fix and adding fluid I will stay away from Dot 3. Will Dot 4 be OK or go to Dot 5?.
@JHutch , If you have done pickup and car brakes - this is very much the same. Jack the tire up off the ground just barely. That way when you take the wheel off the hub you don't have to lift it as high. And when you put it back on the hub, you can lift it with a flat bar to lift it with...
You may need to adjust the brakes in to remove the hub. A lot like a truck or car.
Yes Sir... You definitely need to investigate the leaky wheel cylinder. Might only need to service that one wheel but like you said at 40+ years old it may be worth investigating ALL 6 wheels. I also doubt that there is DOT-5 fluid in your system. DOT-3 is what it came with. Any way you go, you need to go one way or the other...
The set up you are looking at seems to fit the bill. I personally donāt use that much equipment. A simple brake bleeder, a wrench to fit on the bleeder fitting and a container to catch fluid.25 gallon tank
Great. But I gotta jack her up to change wheel cylinder seals. Wish I didnāt have to jack her up. Getting a 20 ton bottle jack and truck safely stands. Metal plate.The set up you are looking at seems to fit the bill. I personally donāt use that much equipment. A simple brake bleeder, a wrench to fit on the bleeder fitting and a container to catch fluid.
Start by filling the brake system. Then pump the brakes a few times to try and build up pressure. Next, go underneath, starting at the recommended position, and open the fitting slightly to help air escape. Then itās just a matter of working your way through the system. I try to have a helper with me to pump the brakes.
Jacking up the truck isnāt really necessary unless you are like me with a mid section thatās got too many inches around. In my less fat days, I could use a creeper and scoot around under the truck.
The TM is the most important reference you use. Follow those instructions to the letter in order to get a positive outcome.
