A/C Diagnostic help
thoner7
235
NE TN
I received my valve in the mail. Is it normal for the thing to go past its “full open” and then restrict flow again?
One pic is the max open the valve will actually be. Other pick (less daylight) is when the lever is all the way to open
Thunderbirds
490
Northern Black Hills South Dakota
I think it is normal since the push pull cable will only activate the valve a 1/4 turn. Some have a "stop" detent built into the valve, but most do not.
Tiwaz
64
Miami Beach
I must say: SUBSTANTIAL IMPROVEMENT in the A/C temperature after installing the valve, also I have to say that previously I had disconnected the servo and manually pushed the little lever all the way forward but realize that it DID not slide all the way even gently forced with players, (sometimes that valve gets stuck).
thoner7
235
NE TN
I installed my valve. No cable yet. But it seems to let fluid through, even when shut. I stupidly ordered thenone
At idle, My front ac is only cool while the rear unit is cold.
with any rpm the front begins to heat up real quick while the rear stays cold.
so I’m guessing it’s a bad valve or maybe I installed it backwards??
DREDnot
571
Phoenix, AZ
I have my original metal cable actuated valve and kept it while I retrofitted my truck to the latest AC system. Just got it charged up today and it blows cold. I checked the valve visually before reinstalling it and after installing it I function tested it to see if it fully blocked hot water flow to the heater core. It has a large range of motion and needs to be fully counterclockwise against the "stop" to be fully closed
Tiwaz
64
Miami Beach
If the valve is like the one depicted in #66, there is no right/wrong way to install it, that is the one I have and it either stop the flow or lets it through.... (or anywhere in between) regardless of the "Direction" you installed it in.
thoner7
235
NE TN
It’s the value in my post 66. Maybe it needs to be banded all the way closed? Idk- but as is it doesn’t work. Bought it from rock auto.
DREDnot
571
Phoenix, AZ
That valve should be turned 180 degrees and mounted on the heater side of that elbow to be oriented properly and to accept the cable correctly. The coolant to the valve/heater should be coming from the crossover assembly (that has the thermostat housing). The coolant from the heater returns to the water pump
DREDnot
571
Phoenix, AZ
Adjustment is done while the cable knob is pushed in. Slide cable sheath to the left till the arm hits the lower side of the stop. Tighten clamp. Now when you pull the heat knob out it will open the water valve till it hits the upper side of the stop. Notice the "OFF" and "ON" lettering on this original valve.
thoner7
235
NE TN
So are you saying mines on the wrong hose or on the wrong side of the elbow?
I installed it exactly where the other one was, but I’m replacing the newer electric controlled valve with the manual one.
thoner7
235
NE TN
Well I went to Lowe’s and bought a 3/4” Pex B valve that works perfectly. So the one from rock auto I bought must be defective.
PS Pex A valves are too big. You want Pex B
DREDnot
571
Phoenix, AZ
Your location was where the original electric valve was. Fine spot for the actuating wire to reach it but not ideal if you were going to use the cable actuated unit. Then you would need to mount it as in my pics. Your placement is probably best for using the manual handle you went with.
thoner7
235
NE TN
So the last issue I am having with my AC, may not be an issue at all. It pertains to the rear evaporator like in the 1165 and 1151.
It will randomly shut off(stop blowing air) and then start back up again 30 seconds, a minute, some short time later. The front evaporator blows as normal during this time. Also, the rear evaporator doesn’t seem to have a high/low setting like the front. It just blows in what I assume would be high, the whole time.
maybe both of those are normal? I wouldn’t know. Or maybe it’s a safety shutoff for some reason.
if anyone with more knowledge of these trucks could chime in, I’m always very thankful.
