Kevin Means
- 16
- 3
- Hereford, Arizona
While removing all the nuts, bolts and brackets to get rid of the spare tire carrier, I noticed that there's a shunt attached to it. Is there something in this vehicle that requires a shunt? The house battery bank will have a shunt to determine SOC but I'm not worried about that for the chassis. Is there a reason to keep the shunt, or can I just bypass it and get rid of it?
(A similar question for the polarity protection device) We're converting the truck to a 28 volt (only) alternator. I'll down-convert for my 12 volts inside the cab with a Victron device. Is there any reason to hang onto the polarity protection device that's mounted on the spare tire carrier? Thanks
Kevin
Kevin
