Ronmar
- 8,307
- Port angeles wa
Yea it could be...
the ECU uses a Pulse Width Modulated signal to control that pressure reg valve Based on what it sees on the pressure sensor. So if the system doesn’t see a sensor, it will either not fire the injectors same as if it does not see adequate pressure, or it will detect that no sensor is connected and feed a basic PWM signal to the regulator valve that will deliver an adequate if not ideal injection pressure to allow the engine to at least function with a check engine light…
If you can read ECU sensed pressure with cat ET, you could pretty easily rig a test source with an old grease gun, oil a T fitting and a pressure gauge to compare cat ET sensed pressure to that applied by the test rig to the gauge and sensor…
