Found a gas powered wrecker
WillWagner
3,156
Monrovia, Ca.
Yes I bought it to save it. Working on carb then air roto chamber leak. Then a good greasing and lube
See if you can locate the Zenith. Night and day difference in starting and fuel usage. Also invest in the NGK/Brent Mullins plug wire adapters.
turnerman
54
landrum, sc
Got the zenith carb to install. Will have to rework linkages because of the previous Holley swap. Thanks for the plug info. The plugs I was hoping would last for some time because I still have not found a roto chamber I could afford or rebuild seals to repair. I know this if it sits through a rain in the yard it sinks 2 inches in the ground so it must weigh 60000 lb
