LOCATION??If anyone has an interest in what I believe is a m543 wrecker maybe from Korean era. It is a gasoline model. No pictures yet but if there is any interest I’ll get some
old post ... without revisiting the entire string i believe he bought itLOCATION??
See if you can locate the Zenith. Night and day difference in starting and fuel usage. Also invest in the NGK/Brent Mullins plug wire adapters.Yes I bought it to save it. Working on carb then air roto chamber leak. Then a good greasing and lube
haha it sure seems that way at times, especially on muddy ground .. But M62's are "only" 34500# thereabouts ..I know this if it sits through a rain in the yard it sinks 2 inches in the ground so it must weigh 60000 lb
I can take pictures of a stock linkage if you like.Got the zenith carb to install. Will have to rework linkages because of the previous Holley swap. Thanks for the plug info. The plugs I was hoping would last for some time because I still have not found a roto chamber I could afford or rebuild seals to repair. I know this if it sits through a rain in the yard it sinks 2 inches in the ground so it must weigh 60000 lb
I will do that next week. Only there Tu. & Wed.Please on the pictures that would definitely help.
does anyone have a lead on roto chambers? Still looking for the one on this m62. Thanks
How many work at the moment?Love M62 wreckers! I have 2 of them![]()
Both now after you shamed meHow many work at the moment?
