Need Help Diagnosing Fuel Delivery Issue
WWRD99
1,861
York Pa
Yeah i plan on posting pictures of the pumps later - the one i pulled off of it that i got a replacement for is the incorrect one that does not work. But you can see when comparing them that both the plunger arms are still slightly different, even though they are the same style, which makes it even weirder that it worked for so many years .......
After putting on the correct one last night, i got fuel to the filter within about 10 seconds of cranking.
And i have a big boster charger hooked to the batteries that i turn on whenever i am going to try to start it. Havent left it on overnight as i worry about it getting hot.
Mine has been converted to 12 volt too
Yeah the difference is the arm angle. They look identical at a glance and most don't think about it. So it's 12 volt...did they change the battery cables to a larger guage? If you have a 10 or 20 amp setting and good water levels they should be fine. Check the starter for the front bracket if you haven't already. They have to change the starter in the conversion...might have left it off.
huskerfan
9
Lincoln, NE
I believe they did yes. Like i said, it has ran fine for years with no issues lol
And yes i have replaced the started many times with the gear reduction one as i usually go on 2 river trips each year and the starter isnt a fan of being swamped in 3-4' of water, but O'reillys and their warranty always comes through lol
huskerfan
9
Lincoln, NE
Well guys plugs was an issue. Pulled them all and only 1 of them didn’t ohm out. Put all new ones in and finally got it to fire up and run but had to massage the throttle a little to get it to stay running. But if I gave it a lot of throttle, once I let off, it would die. It’ll fire right back up, but idles rough, and if you give it throttle, it’ll die when you let off the pedal, unless you let off really really slowly. Here’s a video:
I even switched the fuel pump line and ran it to a Jerry can full of diesel to rule out anything upstream, but had the same issue.
anybody got any ideas on what to check next?
WWRD99
1,861
York Pa
Did you put the clear fuel line on the ip return yet?
