Need Help Diagnosing Fuel Delivery Issue
WWRD99
1,942
York Pa
Yeah i plan on posting pictures of the pumps later - the one i pulled off of it that i got a replacement for is the incorrect one that does not work. But you can see when comparing them that both the plunger arms are still slightly different, even though they are the same style, which makes it even weirder that it worked for so many years .......
After putting on the correct one last night, i got fuel to the filter within about 10 seconds of cranking.
And i have a big boster charger hooked to the batteries that i turn on whenever i am going to try to start it. Havent left it on overnight as i worry about it getting hot.
Mine has been converted to 12 volt too
Yeah the difference is the arm angle. They look identical at a glance and most don't think about it. So it's 12 volt...did they change the battery cables to a larger guage? If you have a 10 or 20 amp setting and good water levels they should be fine. Check the starter for the front bracket if you haven't already. They have to change the starter in the conversion...might have left it off.
Sent from my SM-S906U using Tapatalk
huskerfan
14
Lincoln, NE
I believe they did yes. Like i said, it has ran fine for years with no issues lol
And yes i have replaced the started many times with the gear reduction one as i usually go on 2 river trips each year and the starter isnt a fan of being swamped in 3-4' of water, but O'reillys and their warranty always comes through lol
huskerfan
14
Lincoln, NE
Well guys plugs was an issue. Pulled them all and only 1 of them didn’t ohm out. Put all new ones in and finally got it to fire up and run but had to massage the throttle a little to get it to stay running. But if I gave it a lot of throttle, once I let off, it would die. It’ll fire right back up, but idles rough, and if you give it throttle, it’ll die when you let off the pedal, unless you let off really really slowly. Here’s a video:
I even switched the fuel pump line and ran it to a Jerry can full of diesel to rule out anything upstream, but had the same issue.
anybody got any ideas on what to check next?
WWRD99
1,942
York Pa
Did you put the clear fuel line on the ip return yet?
WWRD99
1,942
York Pa
I had an injector line cracked when i fired it up, wouldn't that have gotten most of the air out?
Not at all. The other 7 would need cracked if you wanted to get all the air out.
huskerfan
14
Lincoln, NE
So i should put the clear hose on there and see if there's an air bubble right?
Does going through and cracking all of the other injectors get me anywhere? Seems i remember reading on a thread on here about the clear hose, but not really about guys needing to go through and crack injector lines individually.
WWRD99
1,942
York Pa
The clear line shows bubbles and very nice to have the knowledge that it has air in the fuel or not. No guessing. You do need to crack every line a bit to get the air out. If you can get it running and have someone hold the throttle up some and crack each one quick it won't take long.
Barrman
2,245
Giddings, Texas
The die when you let off the throttle but start right back up again thing.
I have experience with several trucks where the only cure was an injection pump rebuild. 100% success fixing the problem.
I also have about 50% success with new fuel, filter and just run the truck on the road at least a few miles everyday. But if it is so bad that just letting off the throttle when topping a hill turns off the engine. It is normally too far gone, get a rebuild.
huskerfan
14
Lincoln, NE
It's just so weird to me that this randomly started happening one day at an offroad competition. I thought if the IP is going out, the symptoms of that slowly come about? My truck has never just died while running. I remember it vividly because i didn't even realize it had shut off i was so shocked by it. But then it would keep dying as soon as i would let off the throttle the rest of the competition and ever since, which was back in November
Barrman
2,245
Giddings, Texas
Pull the check valve in the return line on the top of the injection pump. Look inside and see if there are little black bits in there.
huskerfan
14
Lincoln, NE
[/QUOTE]
Already tried that and there were no little black pieces or anything - i could see light through the little glass ball
huskerfan
14
Lincoln, NE
Well I tried again last night - got it fired up and still the same problem. Installed the clear hose like mentioned, and there was not an air bubble when it was running. Only after shutting it off did a small bubble form.
View attachment IMG_0984.jpgNext i tried cracking injector lines while it was running and had about 20% throttle. It would idle down each time i cracked an injector line, and spurt from the hose under pressure, then would idle back up once i tightened the nut (understandable i am thinking since then there would be pressure back in the system again):
You can see below that there is a bit of rust inside the governor housing, not sure that that matters since the fuel looks clean? Fuel Wouldn't be too old or anything. Within the last year easy
It just seems to me like the IP is running and working but there is some other small issue causing the timing to be off? Or maybe i am wrong and this is a key symptom of an injector pump going out?
CARC686
710
New Mexico
I only say that because I wasted my time and money hoping it wasn't the injector pump when I had your exact symptoms. I ate a lot of noodles that month, but I managed to pay for it. Just remove the lines from the injectors and pull the pump off like a steel spaghetti spider. Take pictures, and label all of the lines for reference or you'll be scratching your head later.
huskerfan
14
Lincoln, NE
Well i messed with it some more last night - adjusted the idle screw on the drivers side of the IP by the throttle cable, still same problem. It is just weird because it fires right up, and doesnt smoke. Idles somewhat fine after it warms up a bit. But after you let off the throttle, unless you let off it very slowly, it'll die. Fires right back up immediately like nothing happened though. I have a buddy that said i can pull the IP off of a 6.2 in his shop, but i am trying to avoid that.
I did read on this thread https://www.dieselplace.com/threads/my-6-2-will-start-and-idle-but-has-no-power.345431/ that the guy had a stuck metering valve, and the picture he posted looked like the metering valve was in a different position than mine is from my picture above? Wondering if maybe that could be my issue? Was going to pull it out and clean it up tonight
