Mep 803a No/Low Low Power Output
Iron.Horse
15
Frederick, Maryland
10 terminal block reads 12.2 on upper wires, not disconnected. Little tricky to get in there. A1 test, with wires disconnected is a crazy bizarre reading in the 60.0 range. I triple checked it and every time got a different reading, but it was definitely no lower than 50-60 ohms
kloppk
4,028
Pepperell, Massachusetts
The resistance should be the same 12.2 at 10 Terminal block AND across the two wires behind the gauge panel.
Your 50-60 ohms indicates a poor connection between 10 and one or both of those wires.
I mentioned to check, inspect, clean the P4/J4 connector pins in post #12. Did you do that?
Iron.Horse
15
Frederick, Maryland
Yes sir, found J5, pulled it apart and sprayed it with electronics cleaner. I honestly have looked everywhere for P5 but haven't found it yet. I'll try to look again for it.
kloppk
4,028
Your DMM is actually displaying 76,300 ohms (7.6 KOhms)
P5 and J5 connect together.
J5 is bolted to the floor of the compartment behind the gauges. A small black connector with 4 wires..
P5 plugs into J5 behind the right access door.
P5 also has 4 wires.
Do you know how to decipher the -24 TM to figure exactly how it's wired from A1 to find 10?
The TM wiring method can be confusing to figure out...
edit:
Here is a quick drawing showing the actual wiring...
Iron.Horse
15
Frederick, Maryland
edit:
I Really, Really appreciate the drawing and help... The tracing of wires makes a lot of sense, I pulled J5 again and sprayed it, traced the wires and looked for rubs and chews, they look fine. The original spade connectors were replaced with permanent crimps, wires seem solid. I guess I could cut them out and re-splice for good measure? Wires seem fine going into gen head, no rubs, but I can't see where the one set terminates on the... coil? Only the other set on number 10.
Should I cut out the larger wire that lays on the gen head and replace from the plug to where it enters the head? That would eliminate a few feet of wire that could have internal damage?
