A/C Condenser placement for an A1R
IronhorseTX
Dallas Tx
Hey folks, I’m starting to do the GEN two a/c install for my 2007 1085 A1R. Curious if there’s any documentation or if you guys can guide me on where the original placement is on the Reddot AC condenser on an A1R? Is it placed up front next to the radiator?
GeneralDisorder
5,983
Portland, OR
My thread on AC install on my A1R:
2008 M1079 A1R/A1P2 factory Red Dot condenser:
IronhorseTX
Dallas Tx
Good news - no bracket needed. Found another way to mount it.
BUT the plugs don’t align to the trinary switch to the dryer I bought. Anyone know what plug is needed for this switch??
Ronmar
8,132
Port angeles wa
Ok, that looks like a config for separate hi and low pressure switches, and not a trinary switch(both hi and low combined)… you either need a new receiver/dryer with dual switches, a new harness to match your dryer with trinary switch, or to modify your existing harness and add a pigtail to connect to your existing dryers trinary switch… i think you will probably find that one pin in each of those connectors is either B+ or ground(common) connecting to the remaining 2 pins for high and low pressure indications respectively…
FarmingSmallKubota
1,317
Wapakoneta, Ohio
