803A engine help
spark500001
10
novi michigan
Hello, we just bought a 2010 MEP803A generator from Gov planet it has 100.9 hours on it. it was bought as non-running but, in the video, it has oil pressure. we are trying to get it operational.
we cleaned out the fuel tank and all the IP fuel pumps and installed new fuel injectors plus filters. it will turn over (good cranking speed) slight amount of white smoke shows. in further investigation we all the intake rockers were cracked, and pushrods are bent. the crankshaft and camshaft marks appear the line up.
we replaced all rocker arms and pushrods. another attempt to start was tried and all the intake rockers are cracked again.
does anyone have any idea of where to go next or what TM we can look at ?
Thanks for any help or suggestions
Ray70
7,040
West greenwich/RI
When you tightened the rocker arms did you follow the instructions and allow the lifters to sit and bleed down for 1/2 hour , then rotate the motor by hand and let it sit again before cranking the engine?
If you don't the lifters will be pumped up, causing the valves to hit the pistons and bend the pushrods.
I can't say I have ever seen cracked rockers, but I've seen plenty of bent pushrods.
If you need more pushrods and/or rockers I should have several sets of used ones available.
You need the engine TM available here:
spark500001
10
novi michigan
thanks Ray, we followed the TM when we installed the new rockers and pushrods . is it possible that the gear has moved on the camshaft ? the crankshaft key is still in the slot so that was the only thing we could think happened at this point.
thanks for your input
Ray70
7,040
West greenwich/RI
Anything is possible. I believe the LPW4 gear is held to the gear with a slot in the cam and tang on the gear. Perhaps the ears of the slot in the cam have broken off. Only way to know if to pull it off.
You could try pulling the #1 injector and valve cover and stick a screwdriver of rod down the injector hole so its sitting on the piston.
Crank the motor to TDC and see if both valves are closed as you pass by BDC and are still closed as you pass by TDC.
The exhaust valve should start to open as you approach BDC again.
This is a crude test but if the cam is way off it should be pretty obvious to see.
Ray70
7,040
West greenwich/RI
Also we had pressure coming out the intake and suction on the exhaust manifold
That's a sure sign that the valve timing is incorrect.
It sounds like you should just go ahead and pull the timing cover off and take a look..
See if there are signs of someone else being in there previously.
Perhaps someone assembled things incorrectly ( timing gears improperly aligned ) or perhaps something has broken.
AND.... make sure the engine is cranking in the right direction!
There is a starter for the MEP-701 ( IIRC) that looks exactly the same as an 802/803 starter. It bolts up the same, but cranks in the opposite direction!
I once ran into the same thing ( pressure in the intake and suction on the exhaust) while working on a 701. Turned out it was because the starter died and the replacement I had on my parts shelf ( which I think was for an 802/803 ) spun in the opposite direction.
spark500001
10
novi michigan
We removed the front cover and the crankshaft key appears to be intact and in the proper spot. the timing marks are lined up when the engine is rotated . when we watched the rocker arms they seemed to be around 90 degrees off what the timing marks show .also there are spots when rotating the engine where it gets tight like we have interference . the engine doesn't looked like it was taken apart before . we are now scratching our heads of what is wrong.
2Pbfeet
1,433
Mt. Hamilton, CA
As @Ray70 points out I would suspect that there is something amiss with the camshaft, probably its gear.
To me, the "rocker arms they seemed to be 90 degrees off" and "...there are spots when rotating the engine where it gets tight like we have interference..." are consistent, and both point to doubting whether either crankshaft key or the cam gear ok. When they are lined up, where is cylinder #1 relative to TDC? At this point, I would verify by removal that cam gears are correct. I would also consider pulling the head, and seeing if the interference goes away. I suspect it will.
While I like @Ray70's suggestion of the 701 reverse direction starter, I don't see how that would generate interference.
All the best,
2Pbfeet
Ray70
7,040
West greenwich/RI
Don't rely just on the alignment dots. I'm talking about making sure the cam gear is attached to the camshaft correctly.
I think the end of the cam has a slot cut in it and the gear has a horizontal bar sticking out that locks into the slot in the cam.
Make sure the end of the cam didn't split and allow the cam to slip relative to the gear.
Mark T
Mi. 48185
Ray70
7,040
West greenwich/RI
That's the crank key, I'm curious about a possible issue with the camshaft and / or the attachment of the cam gear on the camshaft.
spark500001
10
novi michigan
we locked the cam and crankshaft gears with a rag and tried to see if there was any movement there wasn't . its too bad we don'tcamshaft gear.jpeg have a photo of the camshaft end in relation to the slot to see if that might refence where the gear is to the cam.
2Pbfeet
1,433
Mt. Hamilton, CA
We are trying to make sure when we have to order parts for this engine . that we have the right model of engine right ?
Hoping for help on this
That is the data plate for the engine. How useful it is might be a different item. What parts are you ordering?
There's ordering MEP-803A parts, there are Onan specific parts, there are Lister Petter (LPW4) model parts, and of course generic parts. The most specific is always going to be MEP-803A parts, but more general parts may match, e.g., Lister made a variety of engine versions, but bear in mind that not all versions share the same components, so some care is warranted.
All the best,
2Pbfeet
