803A Hits a Wall at 9.3kW
Tinstar
2,624
East of Edmond, Oklahoma
Might I suggest that you add a bit of seafoam to the oil before changing it.
It does a great job of cleaning inside the engine and hopefully freeing up piston rings.
Yes it’s safe for that, says it right on the can.
Just can’t run it forever.
I don’t remember the max amount of time it can stay in before dropping the drain plug.
If that doesn’t work, then try the methods already mentioned.
I would try all sound suggestions before tearing down the engine.
cstumpf750
94
The Jersey Shore
The proof will be when you run it under load. If your oil pressure is higher and it will sustain a load longer than before, that’s progress. I would load it to just below the previous max and see what it does.
Ray70
7,224
West greenwich/RI
Got to run it today. Definitely has blow-by. Not as much as some people have posted about on here. Not shooting oil out of the fill hole, and doesn't pop the dipstick out when running, but definitely positive pressure in the bottom end. I can feel each cylinder's compression compression stroke. It's still holding right at 20psi oil pressure.
Since I've put about 6.5hrs on it, would you suspect a full engine rebuild is needed, or just some engine restore and a couple of hours of hard running?
Haven't even begun to look in the manual for engine rebuild instructions and part numbers, so no idea the time I'd have to put into it. Only ever fully rebuilt small gas engines that can be done easily in a day.
How are you measuring the backpressure? Are you using a manometer, of judging it simply by feel?
The 803 and by far worse, the 802 can be deceiving if you just go by feel with the oil fill cap off because of the crank and pistons pulsing up and down.
To test compression I made a steel tube the shape and size of an injector that bolts right in place of an injector. It has an o-ring on the face to seal to the bottom of the injector hole and the center is threaded with a 1/4" NPT to accept any compression gage.
I have also seen the old school automotive compression testers with a rubber tip that you just push against the hole, but the gages usually won't go up to the needed 350+ PSI and I'm not sure you could old back 350 psi by hand.
CallMeColt
1,738
Wilson County, Texas
This seems to be exactly what mine did in this video series..... head gasket was bad. It eventually kept getting worse & ate all the coolant & blew the engine.
handyjay03
Louisiana
Not losing coolant or gaining oil. In fact, when I changed the oil from the previous owner, it looked well used (no burnt smell, but black). This would indicate to me that no coolant is getting into the oil. Looks like yours was smoking much more than mine, and then had the telltale white smoke. None of that.
Haven't had time to mess with it because of the holidays. I'm sort of leaning towards a combo of stuck rings and bearing clearance being the two problems with this machine.
Ray, I am not actually testing back pressure. Just putting my fingers over the oil fill port or the dipstick tube. I can feel positive pressure there
CallMeColt
1,738
That's good. The video I shared is when it was at it's worst. It was barley showing at the beginning & I suspected stuck rings. Just a suggestion!
handyjay03
Louisiana
Had some time before I picked up the kids to start working on it. Man, I feel like whoever makes 5/16" bolts had an "in" with the feds. After soaking half of the bolts, took like 30 minutes to get the top cover off and not lose any nuts. Soaked the muffler bolts with PB Blaster and plan on pulling that tomorrow so I can pull injectors and pour some seafoam in the cylinders. Will let that soak all day while I work on some cars, and get everything back together hopefully tomorrow night
handyjay03
Louisiana
Well, got all injectors out except the third one. Doesn't want to budge, and looks like it hasn't ever been out.
Muffler had some unburned fuel on the gasket. Injectors were full of carbon, so probably need a soak. Fuel return line going to injectors is original and broke in one spot behind the engine when I was wiggling it out of the way. One big concern I have is when I started, I unbolted the hard fuel line from the top of the valve covers. On two of the nuts, the o-ring came out intact. One, it came out in three pieces, but I had to dig the last piece out. The fourth o-ring was in a bunch of pieces, most of which went into the valve cover. I did notice it was oily by that nut before I removed it, so there's a possibility it has been damaged for a while. I guess that one is coming off (hopefully with a beautiful looking gasket). Are these just standard viton o-rings?
handyjay03
Louisiana
After probably 20 minutes of back and forth with a crescent wrench and screwdriver to turn it, I was able to get the last injector out. Also placed an order from McMaster for new o-rings since no one around here had the correct OD and thickness that was on it. Popped valve cover off to get the broken o-ring, and everything looks almost brand new.
Before I called it a day, spun it over with the dead crank a few times and poured some fresh Seafoam in the injector ports. Would've been nice to have the o-rings in my stash, but just had cheap Chinese ones
Ray70
7,224
West greenwich/RI
A couple suggestions for everyone:
When an injector totally refuses to budge, the thread on top for the hard line is the same as some automotive metric lug nuts, 12mm 1.5 or 1.25 pitch ( dont recall which off hand ) you can thread the appropriate lug onto it and use adapt a dent puller ( slide hammer ) to grab onto the lug nut. Even the most stubborn injector won't stand a change!
2nd: The top of the pistons on those engines have a huge donut shaped dish in the top. Pouring sea foam or ATF etc. into the injector hole will put all the fluid into the dish rather than against the rings. If you're trying to soak the rings, make sure you pour in enough to completely overflow the dished area in order to get it into the rings too. You probably need 1/2 pint or more per cyl.
handyjay03
Louisiana
Wow, that's more than I thought. I went through almost a full 16oz bottle and figured that was plenty. I figured with the amount that was coming out when I cranked it over, the rings were good. It did overflow out of the injector hole on whatever cylinder ended up at TDC initially, and once again after turning it over. Guess I might have to do it again though
handyjay03
Louisiana
After letting it sit for a couple of days with more Seafoam in it, I had a chance to bolt everything back up. Before I did, I ran the dead crank with my finger on the injector ports, and felt compression and vacuum. Noticed on the #2 cylinder that some exhaust was coming out of the injector port, so had to tighten it down a little more than factory specs to get it to stop. Figured that was because of the new copper washers.
Ran it with the exhaust manifold off no load, and there was smoke coming out of the #2 port every exhaust stroke, while the others had none. It did seem like that cylinder was pushing more exhaust, but that could've been a mental thing just due to the visual cues.
I guess next step is to move that injector to another cylinder and see what happens. That one had much more carbon buildup than the others when I pulled it the first time.
handyjay03
Louisiana
Have an update on the injectors after getting them to a shop. It was only $15/ea to test, so I figured why not. All four had good spray patterns. Leakoff rate was close to spec. Two opened up around 3350psi, one at 3200, and the last at 3000. The cylinder that was putting out smoke was the 3000psi one. Going to get them cleaned and set back to 3500 and see what happens before further testing
handyjay03
Louisiana
Got a scope in the cylinders this morning. Cylinder 1 has decent cross-hatching, but a very tiny bit of vertical scoring. Cylinder 2 has a small rust ring where I guess the piston sat when the machine didn't run for a while. This was almost TDC. Also leaking head gasket. Cylinder 3 looked better than the first two. There was a ring from where the piston sat where it was laid up (seemingly exact same spot as #2), but no rust. Decent cross-hatching and no scoring. Cylinder 4 looked perfect.
I feel like the engine restore would cover compression on 1 and 3. 2 would be close. How much time am I looking at spending on a head gasket replacement, or am I looking at a complete rebuild? At this point, I'm not seeing coolant in the oil or oil in the coolant, just a small amount of leakage.
Didn't get a chance to pick up the rebuilt injectors yet. Will do that next week.
Ray70
7,224
West greenwich/RI
Head gaskets are easy! Your first attempt should only take about 3-4 hours tops. After doing a handfull of them I was at about 40 minutes to tear one down and maybe an hour 1/2 to reassemble.
Just don't get too excited to crank it up, pay attention to the lifter bleed down procedure after reassembling the pushrods and rocker arms.
Can you post pictures of the scoring and rust ring?
handyjay03
Louisiana
Will have to later. It's Dinosaur Day at the Colosseum, so I'll be tied up with the kids for a while. Definitely glad I have a smaller OD borescope. This 3.5mm one barely fits in the injector hole
LuckeyD
428
Vilseck, Germany
Good Day: If I read right you say cold and after starting you have 45psi oil pressure and as it warms up the oil pressure starts dropping to 18PSI, the anything below that it will shut off because the LOP is set to that range to shut down the engine. Glad it is not blowing the dip stick out yet. I have seen this a lot and what is happening is the oil is thicker when cold and as it warms up the oil thins. You have wear in the journals, bearings and will have to address a tear down to correct oil pump, and the wear. You can use plastigage on the crank bearings and check ring wear. Sorry for the bringer of bad news to you.
handyjay03
Louisiana
Yeah, I'm not trying to rebuild the engine. Just flat out don't have the time to do it. I get maybe 6 hours a week to take care of non-chores, and that's if there's no parties or people stopping by on the weekend. For that issue, I'm going to run thicker oil and engine restore and see what happens.
Got back late from the dinosaur day, so no time to get pics of the cylinders.
handyjay03
Louisiana
Spent some time and got pics today. After further inspection, I got #3 and 4 mixed up. #3 looks good, and #4 looks the worst out of all of them. Could not see the fluid leak in #2 like I could yesterday, but I can see a rusty drip area and valves are cleaner than I'd like.
Will put pics in order #1, #1 valves, #2, #2 valves, etc
Ray70
7,224
West greenwich/RI
Not to be the bearer of bad news, but cyl. looks pretty bad. Being pitted like that I suspect you have either low compression in that cyl or perhaps no fire at all.
I know you're pressed for time, but if it was mine I would just bite the bullet and go completely through the motor. I've actually fixed several LPW4's in worse condition by using a Lisle micrometer head cylinder hone. I was able to hone the cylinders oversized, starting with 80grit and working up to 400 ( took a long time ) and I got oversized pistons from Mayi Diesel pretty cheap. Or take the block to a machine shop and have it bored. Throw new bearings in it to fix your oil pressure issue and you'll have a brand new machine!
