M1009 vacuum pump replacement and where to buy
Warthog
241
OKC, OK
Check with Doghead here on the site.He had them for sale with all the info you need to change it out. :-D
Doghead has the Vacuum Valves for the Injector Pump, not the vaccum pump itself.
The pump should be available at most local parts stores.
CARC686
697
New Mexico
I just bought a belt-driven vac pump a couple years ago and swapped the pods. It was cheap. The worm gear assembly it mounts to doesn't break. At most, you might want to replace the o-ring on it.
deank
581
Inverness, Florida
