Sitting for 5 years. Help me get it running?! Please!
Ronmar
8,326
Port angeles wa
This is probably THE most common issue with these engines. Hopefully it was not run too much with a leak. makes for harder starting(starter wear) and gallery fuel pressure issues can cause damage to the unit injectors…
Dirtdiggler
17
Seattle, WA
Given how long it sat between operation (7 years), I think this was a new issue. I had it idling for about 20 minutes before the air leak became obvious - essentially 60 seconds of pain at it first started idling lower and then continued down hill. I have only tried to start it twice since. But new fuel lines are here Monday and hopefully it's rolling so we can determine what else needs attention.
And thanks again for all the wonderful info. It's been SO HELPFUL. Will update next week with status.
Dirtdiggler
17
Seattle, WA
Just an update - truck is running well and driving. THANK YOU all but especially Ronmar!
CTIS isn't working - all five lights are on and not blinking. I did read that means I need a new controller, which conveniently I do already have because it was one of those spare parts I wanted with me 8 years ago when it was being continuously operated. If that doesn't solve things I'll be digging in and maybe asking for help.
The tranny is lagging a little (or it could be the throttle response, but feels more transmission) starting in D (2nd gear) and reverse. The fluid was changed it about 7k miles ago (and 8 years 😬) - probably should do that? Or anyone, what's your opinion? Necessary? Possibly helpful?
The air line to raise the cab leaks, so need to fix that so I'm not fully reliant on the hydraulic manual operation.
Finally, if it's easy to point to a good resource for troubleshooting the hydraulic system, repairing, bleeding etc, that would be super helpful. The spare tire function is completely not functional.
Lots of other stuff to work on - the box has a solar and battery storage system I would like to expand and tie into the alternator and cab battery with shutoff etc. And then theres the endless list of preventative maintenance and dream upgrades.
Cheers for now!
Ty
Ronmar
8,326
Port angeles wa
Yea 5 solids is a dead controller. Should be able to simply power down and plug in the new one. Make sure the ground connection at the bottom case bolt is good… CTIS usually has issues with air leakage, and since it is trying to control the air bombs we call tires with a pressure gauge and a stop watch, it will fault at the drop of a hat…
top of the engine is a throttle position sensor for the transmission controller. The TCU relies on throttle position info heavily to determine how it behaves. If that is not working correctly it will be shifting based on min and max RPM inputs Which does not make for smooth timely shifting…
I did a video on checking the sensor operation and telling the TCU to re-calibrate that input signal…
ckouba
1,992
Oregon
Insurance is still absolutely painful to acquire. Anyone. ANYONE have advice based on recent insurance agent interaction that could help?
I am in Oregon and carried through Progressive, insured as a commercial vehicle for private use. It is extremely reasonable through them, but you will have to work to find an agent who actually wants to deal with you. I also had many "No's" before the agent I'm with said, "Sure, no problem!"
Dirtdiggler
17
Seattle, WA
Just got to this. Definitely this is my shifting problem. TPS is roasted. Is there a rebuild solution or do I need to buy one?
Ronmar
8,326
Port angeles wa
Look at Ebay for Allison Throttle Position Sensor… have not come up with an alternative yet but have been looking as that IS an important part of how the TCU determines it’s shifting behavior.
there is a performance teans company that has some TPS’s used to interface their controller to a carbed engine, and it may be close. The issue is that this unit is ~15Kohm and that is a little bit unusual of a size for a TPS, and so far, many of the standalone linear position encoders/potentiometers I have found(5-10Kohm are common)…
Dirtdiggler
17
Seattle, WA
So yeah, got one from ebay. Resistance numbers are TINY. Definitely not going to work.
We do have access to a parts truck - same year m1081. I tested the TPS on it (it's stock) and the values are two orders of magnitude lower, but the range and ratios are equivalent..... I'm going to throw it in because ours is absolutely useless and I can't see a good reason not to give it a try. But damnit, I don't know where to go next if/when that doesn't work. I scoured eBay the rest of the web and while there are tons of Allison TPS's to be had, after this last experience I could see buying 10 of them before getting one that works (or never).
GeneralDisorder
6,137
Portland, OR
ALLISON TPS in various cable lengths
16 Inch Mounting Length 29507766
22 Inch Mounting Length 29507767
24 Inch Mounting Length 29514531
28 Inch Mounting Length 29507768
30 Inch Mounting Length 29509928
