- 166
- 121
- 43
- California
Where is the schematic? I get lost in the TMs. If you could give me a hint, I'd appreciate iteach cable should have a metal tag with a number on it, P something… on the schematic, on the first page or 2, most all the plugs are listed… Y0u can sometimes use the wire numbers on the plug wires to help ID them…
It's a 2003 M1088 A1. I've downloaded all the TMs for the 1083s would it be in there somewhere? OK, I just found the FMTVA1 schematic.well the A1 schematics are in the tech manual section here on SS. Forget what year your truck is?
I'll send you a bottle of Tylenol. It's the most important , most used consumable during overhauls.
The flashers are working now! I have working Hazard lights and turn signals. I did two things: I unplugged the solid state flasher module and sprayed both sides of the connector with electronic cleaner. Then I cleaned up the circuit board using small foam brushes I got all the dust off and the sprayed the board liberally with electronic cleaner There was a LOT of dirt and dust on the board.All the flasher power passes thru the hazard switch(its powered all the time) the flasher output passes thru the turn signal switch. Here is a condensed lighting diagram I drew once upon a timeif the hazard sw gets unplugged the TS wont flash…
The cable should have a metal tag with a number on it, P something… on the schematic, on the first page or 2, most all the plugs are listed… Y0u can use the wire numbers on the plug wires to help ID them also…
I love automagic repairsVery often it's just dirty switch/relay contacts, capacitors that need to reform (radios, etc), and the like. Just USING the vehicle you will often notice that things start working on their own after a little bit of operating time.
Hi, are you familiar with the work Nate Volk as done on his M1088?View attachment 951003
I got the platforms off today, one small one left behind the aux transmission cooler. My next step is to remove the aux transmission cooler
Hi Alberto:Hi, are you familiar with the work Nate Volk as done on his M1088?
He has quite a few videos on Youtube -->
I am in SoCal and I am looking for an FMTV too. Would it be possible to take a look at your track?
Thank You
Alberto
