Just won an auction - M1088A1
dwlindsey
92
California
The turn signals and emergency flashers don't work on my M1088.
I just found the flasher unit:
I tested the flasher box. It flashes with 12v DC hooked up and a test light. I'll clean the connector. Is there something else I should check?
dwlindsey
92
California
While under the dash, under the passenger kick plate, I found three cables with connectors that were not connected to anything.
What are they for?
Ronmar
8,160
Port angeles wa
All the flasher power passes thru the hazard switch(its powered all the time) the flasher output passes thru the turn signal switch. Here is a condensed lighting diagram I drew once upon a time:) if the hazard sw gets unplugged the TS wont flash…
The cable should have a metal tag with a number on it, P something… on the schematic, on the first page or 2, most all the plugs are listed… Y0u can use the wire numbers on the plug wires to help ID them also…
dwlindsey
92
California
each cable should have a metal tag with a number on it, P something… on the schematic, on the first page or 2, most all the plugs are listed… Y0u can sometimes use the wire numbers on the plug wires to help ID them…
Where is the schematic? I get lost in the TMs. If you could give me a hint, I'd appreciate it
flyfishtrailer
1,102
Cool, CA
Not as familiar with anything beyond an A0, but that could be harness points for a winch control switches. That harness was an option in the A0, but may have been included in A1 and above applications (my attempt at a semi educated guess?)
Ronmar
8,160
Port angeles wa
there are a couple unused plugs under the pax dash. The trucks use a generic wire harness that supports different options that may or may not be installed in a particular vehicle...
The A1 schematic table is not as complete as the A0(doesn’t show all the Plugs in the list) Message me and I can Email you just the A0 schematic in .PDF form. Between all the versions, the wiring actually stayed very similar with the same breaker plug and relay designations for the most part… Even a lot of the wire numbers remained the same for particular circuits…
