M1114 and Forging Exhaust
MedicKam
Ventura, CA
So I am installing the forging parts and the exhaust support bracket is next up. Looking under the wheel well I see there is the large lines running to the condenser. It seems that these fall inline with where the bracket should go.
Has anyone tacked this yet? I was thinking of just modifying the bracket so the hose lines can run through it. Any ideas would be great!
Coug
4,768
Olympia/WA
The early fording kit uses a different bracket than the later units with fender mount condensers. Not sure the specifics though
Retiredwarhorses
4,603
Brentwood, Calif
The turbo trucks don’t need the old style bracket in the fender, there is a reinforcement plate installed on the inner fender…still required to have the rubber isolators, but that’s it.
