Mep 806b fuel sender issues
jmenende
422
Puerto Rico
Hey guys.
So i came across a 806b that has an issue i had not seen before. The sender states -6% fuel. Pulled the sender, ohmed it and it works fine. Could it be the backplane receiving unit thats bad?
jmenende
422
Puerto Rico
That sender does no ground with a screw to the sender body. Its a 2 pin connector with the ground in one cable. Maybe trace it back to the main grounding point inside the control box. Will check that out.
Scoobyshep
2,176
Florida
I would find where that circuit lands to whatever is monitoring and you can use a resistor or potentiometer to simulate the fuel sender directly to the input take the wire out of the equation.
You got about three options, sensor wire or input sounds like you've eliminated the sensor.
Sent from my SM-S908U using Tapatalk
LuckeyD
300
Vilseck, Germany
Good Day everyone. The sender is connected from the sending unit straight to the I/O TCM 100 module with 2 wires. The senders get trash in them and dirt. Pull ,clean, and while drying use the attached an old fat dude put together and check up to the J23 pins 5 and 22. Make sure the wires are tight. The senders do go bad, but I found a lot of times the wiring and connectors need checked, cleaned and ensure they make connection. See if this helps------
jmenende
422
Puerto Rico
Alright. Problem has been fixed. I removed the sim and tightened all screws on the terminals plugged in the backplane. Got a surprise when I removed the sim. The back screws on the main connector had been snapped into the nuts and it was just pushed into the connector. Running the set for some time would have caused it to fall off. I was lucky to have a parts unit i could take the bad screws and nuts from. Id like to have spares of anyone knows the details on them. Thanks
Scoobyshep
2,176
Florida
Go on amazon and look up circuit board standoffs
