Mep 806b fuel sender issues
jmenende
416
Puerto Rico
Hey guys.
So i came across a 806b that has an issue i had not seen before. The sender states -6% fuel. Pulled the sender, ohmed it and it works fine. Could it be the backplane receiving unit thats bad?
Scoobyshep
2,146
Florida
I would find where that circuit lands to whatever is monitoring and you can use a resistor or potentiometer to simulate the fuel sender directly to the input take the wire out of the equation.
You got about three options, sensor wire or input sounds like you've eliminated the sensor.
Sent from my SM-S908U using Tapatalk
LuckeyD
53
Vilseck, Germany
Good Day everyone. The sender is connected from the sending unit straight to the I/O TCM 100 module with 2 wires. The senders get trash in them and dirt. Pull ,clean, and while drying use the attached an old fat dude put together and check up to the J23 pins 5 and 22. Make sure the wires are tight. The senders do go bad, but I found a lot of times the wiring and connectors need checked, cleaned and ensure they make connection. See if this helps------
