hawk-aggie
- 68
- 28
- College Station, Texas
I have more data, but left my notes at the shop. Tried a lot of options, including isolating each wire/cable to the alternator. We started removing the negative battery cable to see if the truck would shut down, before pulling 54A lead. When we had the large positive cable disconnected from the alternator, it did shut down when we pulled the negative battery cable off the post. If it is running when the negative battery cable is removed, it's getting its ground from somewhere else. The issue now is finding where. Maybe the alternator itself. I have 3 working alternators and two working regulators to play with. more info to come later this week.If I understand the response to be "NO" as this is an important starting point with the crazy symptoms.
Got a non runner , but got it running, wont turn off unless one pulls the 5A lead on the fuel cut off solenoid.
Walking it back ... all the obvious connections stated, switch, boxes, alternator and the like covered. ? Factory wiring, NO modifications / hack job going on? I would... and I think you'er wondering what is holding the fuel solenoid energized.
More data time. Monitor the 54A lead (tap into it) while properly connected. Would be interested in the voltage in all states, STOP, RUN, STARTing and back to Stop.
I would like to know the condition of the engine and body connectors ? Rusted, busted, corroded can be suspect. Pictures helpful.
These type of problems are going to require eyes on all connections with prints and understanding. Some obvious and looks like you have ruled them out
? The many box swaps is interesting... BUT then, I am NO fan of smart anything LOL.
HumV wiring is pretty straight forward. Harnesses are well made. One thing that is a bit to troubleshoot is there are splices internal to the design. This make it a little tricky to isolate individual circuits feeding... in this case the IP, but other components share the same. Look at the fan control, TDM, TSU and even the "BOX" We all know those boxes fail and everything goes thru it.
More history of the rig is helpful or just jump in and follow the trail to a can of worm... then success.
I don't like to guess this or that, poking and pulling wires might work???
That's what the Dr. does when one is up on the table, CAMO
>>>>> HUMV ________OWNER >>>>>>>>>>> Good Luck
Bottom line is that the truck is running when the negative cable is removed from the battery.
