.. right! Carry on.These switches were salvaged from a United Airlines 747-400. The Overlays are being engraved. Here are the plans and an example.
Thanks,I also found that the defrost hose needed to be installed prior to installing the vents. Not a big deal. However step one was to install the defrost vents.Nice work. I'm in the final stages of installing Vintage Air in my M1028 rebuild. Just a heads-up - The kit comes with a length of 2" flexible hose for the defroster vent ports and 2-1/2" flexible hose for the cab vents ports. The VA instructions indicate to cut the 2-1/2" hose to certain lengths for each of the four (4) cab vent ports, with the hose stretched-out when measuring. However the length of 2-1/2" hose that came with my kit was insufficient for all four lengths of hose. I emailed VA customer support about this and they shipped me another full length of hose at no charge, and they didn't question my request so I believe they are aware of the deficiency. Also, you may find that the radiator hose which runs from the pressure (cool) side of the radiator to the lower port at the firewall needs to be 3/4" diameter at the radiator but 5/8" diameter at the firewall. VA offers such a transition hose through Summit and other outlets, VA part #99010,
Something else I did when installing the flexible duct was to install a small sheet metal screw over the last internal wire of the hose after it was stretched over the air duct port. The hose must be squeezed to a tight oval shape to fit over the duct ports and getting all four installed on the supply plenum was a bear. A sheet metal screw run into the plastic duct port over the internal hose wire will prevent a hose from popping off a duct port after dash reinstallation. I recommend taking out the defrost ports and installing the hose in your lap instead of trying to install the hose with the defrost ports in place.
Hope this help.
Copy, I plan on using the civilian trays, and have one on each side. Nice work around on your end.Just a heads up - if you are planning on reinstalling the rear battery tray, you will need to turn the top Vintage Air refrigerant line and top heater hose on a 90-degree to prevent the lines from contacting the tray. Those lines exit the VA firewall plate exactly behind the edge of the tray, although the photo below is somewhat deceiving. VA offers a 90-degree fitting for the #10 top refrigerant line, Part #366102. I sourced the 90-degree sweeps from Amazon and ran both lines around the rear battery tray. I used sweeps instead of sharp 90-degree fittings because sweeps do not impede flow as much as fittings.
If you use a civilian tray on the driver's side, you will also need to use a civilian coolant recovery container & mount. Just saying...........Copy, I plan on using the civilian trays, and have one on each side. Nice work around on your end.
Thanks for the heads up.If you use a civilian tray on the driver's side, you will also need to use a civilian coolant recovery container & mount. Just saying...........
Very nice engineering. Most folks have no idea what's involved once you leave the OEM design. BTW, if you need any OEM parts, let me know. I have a ton, all with 15,178 original miles. I plan on listing everything in the Parts For Sale forum after I get finished with my M1028.Now that the body is back on the frame I started routing the wiring harnesses and transmission cable. Also got to work on the engine harness for the indication and glow plug system.
First pictures are the rear windshield washer and the washer fluid supply hose.
Engine to body grounding,and glow plug temp sensor.
Next 2 pictures are routing and cannon plug connection for engine indication systems.
Transmission cable routing.
Then some general frame rail routing.
Last is how goofy she looks. haha
