dunedigger
- 3
- 18
- Hart, MI
I just bought a M1009 blazer last weekend. It ran perfect, on the way home one of the alternators quit working. I ordered two of them so not to worry about the second one going out soon from Napa. I left the wires lay and waited a few days for them to show. So I put them in tonight and got a real bad arc flash from the battery cables and the capacitor on the firewall burnt up. I assumed I hooked a wire up wrong so what I have on the drivers side is a heavy red wire I hooked to the "bat" on the alternator and then a ground to the engine and a smaller black wire on the other terminal and a small black plug in wire on the iso ground. I assume there is no way this side is the problem. On the drivers side I unhooked my wires and the one I had on the negative of the alternator has continuity to the positive terminal block on the firewall. So I assumed I just mixed up both red wires when I hooked it up. Then I was thining maybe both red wires were suposed to go to the "alt" location on the alternator. I tried that and switching the reds and either way I still get a really bad arc flash when hooking up the batteries. Any advice would be great, Thanks
