mangus580
- 282
- 0
- Western NY
You are right, I am wrong. I forgot, I have NO clue what my 1009 has for wiring. I'm sorry.... Hope you can forgive me.
Cheaper yes, but then I'd be back to a 1 off deal, with the harness all hacked up. But, I'll keep an open mind for now,were you thinking, Delta or Wye ....Doghead I'd go with 480 vac 3 phase much cheaper to run.
Don't forget they all use the same key too!It uses the same diesel fuel gauge, idiot lights, headlight switch, wiper switch, wiper motor, ignition switch, neutral safety switch, and much more... then they add on extra wiring to accommodate the second alt. idiot light and a few other things under the hood. Looking at the wiring from an engineering standpoint it is 90% identical. Even 90% of the electrical connectors are the same. I would bet that a large portion of the wiring colors are even identical.
Ok I'm gonna say it... I cant stand it when people cant get through their thick heads that these were designed with an intended purpose as a military vehicle. You guys keep tossing this idea out there because for some odd reason 24V scares you or something... Then people read it... suddenly think "oh thats a great idea"... and then they come back posting about how their stuff doesn't work... trying to get help... and no one here can help them as we don't know what they have... Its a bad idea... Some of us have been around long enough to have seen this happen OVER AND OVER AND OVER again so we highly recomend you DONT!Have you even looked at how simple the 12V conversion is?
http://www.roscommonequipmentcenter.com/news_notes/nn10.pdf
It is so simple because the truck runs on 12V with the exception of the starter, military radio, jumper slave and the glow plugs (up to the resistor). GM could have redesigned the entire electrical system for 24V and made things simple, but they didn't.
Does your M1009 use a 24V headlight switch unique from the 12V version in a Civi truck? Does it use a different dimmer switch? No, it doesn't even use a different heater fan or taillight bulbs.
Seriously, what is so different between the two when you compare them side by side? Just because there are extra wires for the extra systems, doesn't make it completely different. My original point was 90% of the wiring is already the same. Converting to 12V does NOT make it impossible to get help or work on like you stated.
Do you also tell people not to upgrade the weak 10 bolt rear because a 14FF would make an M1009 too hard to troubleshoot brake or driveline problems?
Drill the plug, run about a 2" screw into it, smack one side with a punch until you get a hole in it or spin it sideways and can pry it out... The screw is in case you mess up to stop the plug from accidentally falling into the block!Hi guys, just an update. Truck has been sitting out in the yard since Saturday.
This Sat I will take a voltage reading of both batteries and then attempt to start the truck on the first cycling of the glow plugs. (2 times is probably more like it) Now keep in mind it hasn't been over 25 degrees all week. At night jumping down to around 15. I know its not really really cold but Its just testing the waters as this is my first CUCV. Mabe this weekend I can install my block heater. 1000w. Are they difficult? (frost plug style) Is there an easy way to remove the frost plug?
You do realize your CUCV runs on 12V for everything except a 24V starter... of course not, it's all 24V to you. We have been helping guys trouble shoot electrical problems on CK5 for years without any trouble. If you can't figure it out how to trouble shoot a 12V system send them over there instead, we will be happy to help.If ya want a 12V truck because GM made the CUCV out to be that big of a techinal challenge... go buy a civy K5 and have fun.
That's at least accurate. If you can't help them, there isn't much more that you can do, but there are others out there that still can. Since most of the truck remains unchanged it is just a matter of troubleshooting what they did.If you mess with it, and change it... I cant help. Sorry, but thats the way it is. What more do you want me to say?
Thank you, you just admitted to the problem that we are trying to avoid all together. Instead of spend hours trying to figure out what step they screwed up on, its soo much simpler to instruct them how to fix it the proper way and maintain the original system.That's at least accurate. If you can't help them, there isn't much more that you can do, but there are others out there that still can. Since most of the truck remains unchanged it is just a matter of troubleshooting what they did.
And how many people come in here with problems with the original system? No one would ever screw that up either? People have problems and come here (and other sites) for help all the time.Thank you, you just admitted to the problem that we are trying to avoid all together. Instead of spend hours trying to figure out what step they screwed up on, its soo much simpler to instruct them how to fix it the proper way and maintain the original system.
Please use some punctuation... that is impossible to understand completely. If you want to convert your truck to 12V only there are a couple options. Read through these instructions:well boys i have been following this tread alittle to do a 12 volt convertion go buy 2 100 amp 12 volt alt any good part store well have got mine at napa put in trow restor on fire wall in trash hooked two wires together put 12 volt gear reduction starter in move on very simple have not had any prombles with since no need for all this other stuff i have read just go get new alts hook one two each batt then you know they are chargeing and which is which put new amp gage in move on move on !!!
