What SS is writing about is this: pull the ENGINE STOP out and crank the engine for 8-10 seconds to get the oil filters started on filling up. Then, start it normally. Pumping the fuel pedal when cranking a big no-no.
If you don't do this, then, especially, when it's starting to get a little cold (15-20) degrees) you'll notice the engine starts with a LOT of vibration and is very sluggish until the oil pressure begins to register on the gauge. (insert a mental picture of metal scrapings flying everywhere here...) The engine will crank faster and start a lot quicker if you crank it with the engine stop pulled out first.
Besides, the PM Mag guide for the multifuel operator states that you should always crank the engine that way to check for hydrostatic lock before starting it.
Approach the process of starting any multifuel with dead batteries with caution. If the master switch was left on, the tank pump was running for a day or two. There's a fair chance that some fuel was pushed through the high pressure pump and on into the engine. Give the starter button a short firm stab (a wishy-washy push can cause enough electrical arcing in it to burn it out) and get off the button. If things went "clunk" or attempted to crank and stopped with a bump, stop and find out why.
For those looking for batteries: Interstate is one of the current contactors. Find one of their commecial dealers and ask for U6TLs. They should be able to get blemished batteries for a good price.
Lance
