Fuel pump not working (and how I troubleshot it)
TenTires
225 RPM
52
Tidewater, VA
Ok, Im not saying that this is all inclusive or anything (thats what the "reply" function is for) but my fuel pump quit working and I was able to get it fixed through the advice of some folks outside of the forum, so I figured that I would post about it so that when somebody did a "Search" it would come up and be helpful right off the bat. :wink:
Ok, so this is my first Deuce so Im still learning the ins and outs of how everything works. That said, was hanging out with another member asking him questions when I noticed that when he turned his "electrical" (?) switch on, I could hear his in tank electric fuel pump running and I realized that I had never heard mine running like that, and come to think of it, it was a little harder to start than his so I decided to check it out when I got home (I didnt have my truck there b/c my radiator was in the shop).
So, sure enough, I get home and try it out and nothing. Hmm. Well, what to do now:?: I was told that there was a fuse under the square cover on top of the fuel pump on the tank (pic #1) and at the suggestion of a couple of folks, I figured Id try that first. KISS right? Yeah, not quite.
Come to find out, this was not going to be as easy as I had anticipated (being an aircraft mechanic, I should have known :roll:) because the very first bolt (there's 3) that I tried to loosen stripped out and wouldnt allow me to remove the cover. I broke 3 flathead screwdrivers (the most commonly abused tool in the Navy btw, at least thats what they teach us) trying to get leverage on it but no joy.
So, now Im forced to troubleshoot by other means. Well, the electrician in me told me to check the ground and voltage to the plug going into this fuse box (pic #2). If that was good, then it HAD to be the fuse, corrosion in the fuse block or a bad connection, or the pump itself. I made sure that the switch in the cab was off, then I got out my meter, set it to resistance, found a spot on the frame that was unpainted (that took a suprisingly long time :p) and held one meter lead on that and probed both pins on the plug to see what I got. I got perfect continuity ( 0 ohms) in one pin (good ground) and 180.7 ohms on the other(reading through the switch). Next was to read for voltage. 2, 12v batteries=24vdc (doesnt take a genius) so thats what I looked for . I turned on the switch, went back to the plug and set my meter to VDC and on the pin that I got 180 ohms, I read 24vdc. Perfect! That means that I have good power and ground TO the pump so now to get that cover off.
After much prying and some chiseling (man thats thick paint!) I got the cover off (pic #3). Lo and behold, the fuse was blown. Great news because fuel pumps arent cheap. I replaced the fuse, re-installed the plug and flipped the switch to test out my repair and sure enough, that was it. I did notice that the one wire running from the fuse block into the pump had chaffed on something and had some exposed wire so my guess is thats what caused the fuse to blow in the first place. I repaired that with some silicone and chafe tape and after everything dried, I re-installed the fuse block. I noticed a lot of corrosion on the inside of the fuse block so I treated the corrosion and added some clear RTV silicone sealant in between the block and the fuel tank in the hopes to seal out any further moisture (pic #4) before I completely installed the block again (pic#5) and re-tested the pump after everything dried "just to make sure".
Viola, a simple fix to a simple problem. I never even noticed that it didnt work because of the other 2 pumps, the only "problem" I had was it took a little longer to start than I figured it should (4-5 seconds). Unfortunately, I havent been able to see if this fix has made any difference in my starting time since my Rad is still in the shop, but thats it in a nutshell! :-D
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
Just so you know, if it makes no difference in starting, there is a "bottom" part on the fuel pump. These have a tendancy to fall off. When that happens, the pump does not pump fuel. You can tell by turning the electric on, and opening the petcock on the top of the secondary filter housings. If fuel comes out(under pressure, not just leaks out) you should be good to go. If it doesn't flow, you probably had the bottom fall off. It is more of a pain to get the pump out and retrieve the bottom than it is to remount the bottom plate. I just drilled 3 holes and ran some .020 mig wire through the holes to hold it on. Let us know if you need pics.
gimpyrobb
27,791
791
Cincy Ohio
Sorry, couldn't find them. I guess I didn't get a pic of the wire holding it together. Basicly I drilled one hole on the point side and two on the round end then wrapped the wire through. That cap will not come off now! Also, you should be able to check, with out the radiator in, just don't start her up, or don't let it run long.
TenTires
225 RPM
52
Tidewater, VA
Well there ya go. SEARCH NAZI!
:twisted:<--<-- the smiley makes it all better!
Jerk! (Just kidding btw, see ---->:razz: smiley face)
Anyway, if this is the petcock you were referring to, Id say that Im good (as evidenced by the before and after pics) What causes these pieces to fall off of these pumps? And you really think that I can run my motor without the Rad in (even for a little bit)?
doghead
4 Star General /Moderator
1,193
TT, did you use a 3 or 4 amp slow blow fuse?
50shooter
10
Illinois
If everything is stock, the fuse is suppose to be a 4 amp per 9-2320-361-20, page 3-33
The trick of up sizing the fuse until it quits blowing usually ends badly. In some cases this is what guys did in a pinch and now 25 years later someone pulls one out and notices it is a 20 amp and replaces it as such.
Good luck guys.
gimpyrobb
27,791
791
Cincy Ohio
Yes, a 20 amp is BAD, M-kay. I use a 5amp slow blow cause of the WMO. Yes, you can run a motor with out a radiator hooked up, just watch out for the water spraying out and make sure it isn't long. I would stay inder 3 or 4 min. The heat is from friction of the rings against the cyl walls(basicly). Water pulls that heat out. Some 1/4 mile racers fill the water ducts with concrete and run radiator-less.
TenTires
225 RPM
52
Tidewater, VA
Hmm, I guess Ill change that out (again) tomorrow. How do I tell a "slow blow" fuse from a normal one, whats the difference and why is it better to use over a normal fuse of the same rating?
gimpyrobb
27,791
791
Cincy Ohio
The slow blow fuses allow twice the rated current(milliseconds) at startup of a device. Helps keep the fuse from blowing all the time.
doghead
1,193
The slow-blow is what is called for in the TM, also, a search here on the site will yield more info on the correct fuse, including a Radio Shack part number for the fuse.
A slow blow fuse will say it is a slow blow fuse, on the end of it.(usually has a coil of wire around a core, instead of a simple metal strip inside it.
here's one thread, http://www.steelsoldiers.com/showthread.php?t=24581&highlight=slow+fuse
