trucker 1954
- 0
- 6
- TOMS RIVER NJ
life line batteries are in my trucks cars boats and in my m1028a1 1000 cca at 32 f not cheap but the best iv found 800 cca at 0 f
Is that a deep cycle battery?I just bought 2 walmart marine batts... These were the biggest ones they had, 975cca at 0. They are for my deuce, we will see how long they last. only $76 each
Sorry, just went out and looked closer, 875 cca at 0. They are multi-use: trolling, deep cycle, starting, RVIs that a deep cycle battery?
That seems like a ton of cca's for a deep cycle.
J
There is lots of talk about batteries and what is best, and how many cranking amps, etc, etc, etc....
While the CUCV's came with 6TL's, what is really NECESSARY for these vehicles to start reliably for a good amount of time?
I would argue that using a battery reference to the civilian Blazer 6.2' would provide a good guide. Yes, I know that the civilian version is 12v and the CUCV is 24v...but that fact is effectively irrelevant when you consider Ohms Law. Power=Amps times Volts. How much POWER does it take to turn over a 6.2? Should be the same for either a civilian or military version.
The battery manufacturer guides show that TWO 550 CCA 12V batteries wired in parallel (12v) is what is required for a 12 volt 6.2 powered 1986 Blazer. That would mean that TWO 550 CCA 12V batteries wired in series (24v) should be sufficient for a 24 volt 6.2 powered CUCV. Same total POWER provided by each setup.
My 1994 6.5 diesel powered pickup has operated just fine with TWO Group 75 batteries for its 200k mile life. Any CUCV should operate just fine with TWO 12v batteries that supply at least 550 CCA.
My.
Find cheap batteries with a good, long warranty.
If anyone wants to argue, go find Ohm and argue with his law![]()
I don't see how that is relevant since both trucks started with 6TLs.Just so we're clear, we're talking about CUCV batteries, not deuce batteries.
It might be relevant since we don't know what the vehicle manufacturer called for in CCA's for the Deuce? GM specified at least 550 CCA's for the Blazer, so that is what I based my comparison on.I don't see how that is relevant since both trucks started with 6TLs.
I thought GM put Group 31's in the CUCV's from the factory, but I won't swear to it? The battery trays are designed for either the 31's or 6TL's. You can also get the Optima's and 6TL tray adapters..
