motormayhem
- 18
- 18
- Tucson, AZ
Thats what the slave connector is for. However if it is now a 12v jump start and not the original 24v then the amps going through the wires is doubled.can that slave connector handle that much current to jump start a dead vehicle!? I didn't see any wires in that bundle that looked anywhere near large enough!
if you jump a 12v car.. use the FRONT battery! bad things will happen if you use the back battery, and either of the wires touch the body![]()
