jesusgatos
- 28
- 38
- on the road - in CA right now
I'm building an M109 camper conversion, and one of the things I'm trying to figure out is what I should do for wheels and tires. I'll be towing a 16-18ft enclosed trailer (stretched M353 trailer with an aluminum box) full of dirt bikes and junk. I'm going to be living and working out of this vehicle and trailer, so I'll be hauling a pretty good sized load. BUT, I'm also going to be setting up camp in some pretty remote areas, so I'm trying to strike a balance between on/off-road performance. I'd just like to make the Deuce a little more maneuverable (because I won't always be towing a trailer) without giving up anything when it comes to payload/towing. Possible? The way I see it, I could:
1) Ditch the front axle and leave the rear axle set-up as a dually.
2) Keep both rear axles and install a set of super-singles.
3) Leave it stock. Good enough as-is. Probably true.
Best options for tires in each case?
