spin on secodary fuel filters
nickd
61
Newport, Delaware
I installed a set of the spin on fuel filter adapters on the deuce from John Tennis. It is a quick and easy bolt on installation once the old canisters and gaskets are removed. coupled with the primary spin on fuel/water separating filter I am sure the fuel delivery is squeaky clean.
Does anyone have a suggestion for a use for the old canisters?
Range target?
dabtl
Denton, Texas
I put the old canisters into the city recycle box. There were no tears when the city took them away. I kept the drain valves for future use.
Massm35a2
New Bedford, MA
I'm thinking of putting a NAPA 3626 as my final filter 2 micron, I was looking at the gasket dimentions last night, and it should fit on the adaptor just fine, I am putting a Racor 490R 10 micron as my primary. The 3336 6 micron as my secondary. I run clean fuel from mobil all the time so it should not clog up too fast, I will carry a spair of each just in case.
cranetruck
94
Meadows of Dan, Virginia
The final fuel filter operates with a pressure of 50 to 60 psi, I would suggest that you get some pressure vs flow filter performance data before replacing it.
dabtl
Denton, Texas
My thoughts exactly. I think John Tennis has done a lot of homework on this before it was released.
But, if it works, why not? If it does not work, I believe I will pass on it.;-)
Massm35a2
New Bedford, MA
Here is all I could find, It is also a big filter about same size as 3336
Part Number:3626UPC Number:765809174719Principal Application:Caterpillar 3116, 3126, 3126B & 3126E EnginesStyle:Spin-On Fuel FilterService:FuelMedia:PaperHeight:7.090Outer Diameter Top:3.180 Outer Diameter Bottom:Closed Thread Size:7/8-14Burst Pressure-PSI:440Nominal Micro Rating:2
Part Number:3336UPC Number:765809152274Principal Application:Agco, IHC, Case, Galion, Hercules, Komatsu, Thermo King (Secondary) (6 Micron)Style:Spin-On Fuel FilterService:FuelMedia:PaperHeight:7.827Outer Diameter Top:3.698 Outer Diameter Bottom:Closed Thread Size:7/8-14Burst Pressure-PSI:270Nominal Micro Rating:6
Gasket DiametersNumberO.D.I.D.Thk.Attached 2.729 2.415 0.255
dm22630
42
Front Royal, VA 22630
Are you talking about the old filter housings?
Why dont you save them? That way when/if you sell your truck, you can reinstall the old ones & save the spin-on filters for another truck in the future/sell them??
2cents
If you are talking about used filters....I guess do what the others here have posted....
