Numbers
- 0
- 0
- near Ft. Knox
I cleaned out the Deuce thoroughly today. It's a 1970 Kaiser Jeep model. Found the Jerry Can Straps (STRAP, WEBBING: LIQUID DRUM BRACKET) under and behind the seat structures. Loh and behold I found two of them. One appears to be an inch wide and the other about 1 1/2 inch wide. Same spring loaded snap but different sizes. A picture is included to see if someone can tell me if this is the old NSN 2540-00-968-4060 on the 1 inch wide one and possibly NSN 5340-00-968-4060 on the wider one. Looked through the
2320-209-20P, 2320-209-34P, 2320-361-24P manuals and found two different NSN's and the same part number (8690527) and cage#/FSCM (19207) which to me probably means they changed the material used in the webbing (wide one is different material -nylon?- than the canvas one inch wide one).
In other words, which one is what NSN?
Part number and cage # exists on large one but only a portion of the canvas material exists with no number on the narrow one.
Checked out NSN search device on the web (https://www.webflis.dlis.dla.mil/WEBFLIS/pub/pub_search.aspx) and here but to no avail. Did get some info but none that can ID which NSN is which.
