here is the grill and rad
thabks 4x4 i found itI don't know the TM numbers for that M211 but pretty sure they are in the TM section.
Pull the head off, that'll let you know if you really need to rebuild it or not. If the cylinders aren't pitted from rust, a light hone might clean them up. Surprisingly I've seen a motor that sat outside for years clean up with a hone and using some .001" oversized rings. It's not the best solution, but it's the easiest and cheapest.all right i know what iam gonna do ill strip it down and rebuild it![]()
