1953 m35a2 help
jonsey
orange/MA
hey guys question i wanna replace the straight six i want to run something with more power preferably a multi fuel what do you think
NDT
7,505
Camp Wood/LC, TX
Multifuel at 465 cubic inches wont fit where 302 used to live. The engine will be in the cab with you and the shifter too far back. Some folks have had luck swapping in a 366 Chevy truck engine with an Allison transmission out of a 80's school bus or uhaul truck. Goes right in and the engine can deal with the high rpms at 55mph.
Looks like your 302 is stuck, somone took out the spark plugs a long time ago, and was about to pull the engine when they gave up on the project.
One thing you have going for you is that with all the M-35 deuce bobbing going on, you will be able to get 11 nice mounted tires and a nice bed and troop seats to replace your kinda not usable ones . . .
Better plan on sandblasting the chassis, looks like the rust is about to get out of hand.
jonsey
orange/MA
i need a straight six now tried too turn the crank today and cant turn it so i drained the oil pan and gallons of water came out then oil so i think the engine is seized and i dont have time to take this apart somebody can have the straight six i have i just need one that needs a little work
KI4GSN
Southport, NC
I doubt that engine would be useable even if you did get it to turn over. At the very least, plan on a rebuild. I've used diesel fuel to free stuck engines, but judging by the open water inlet (i think that's what it is) and the way the plugs look, it's shot.
KI4GSN
Southport, NC
I would be doubtful. It may still be rebuildable, but the only way to tell that is to tear into it. I'm sure someone with more knowledge of these motors will chime in, but that's my 2cents
IHASFIP
TEXAS
Well, you definately have a project on your hands. But you can't ever turn free stuff away, well most free stuff anyways. ;-) Have fun with it. Wear gloves, don't want tetnus.
D
tm america
25
merrillville in
looks like one really nice free m211 .dont let the haters get to you they are just mad they didnt get it.you have alot of work a head of you but parts for them are cheap and fairly easy to find.its a gm 302 motor in there i beleive auto trans is cool .dont know why they stopped using autos when they went to the m34-m35 series truck
tomesee1
warren/pa
ive got a m211 sitting in the woods pm me if you need parts or whole truck it runs or did anyway can check out if you want
Jakob
Louisville, KY
all right i know what iam gonna do ill strip it down and rebuild it ;-)
Pull the head off, that'll let you know if you really need to rebuild it or not. If the cylinders aren't pitted from rust, a light hone might clean them up. Surprisingly I've seen a motor that sat outside for years clean up with a hone and using some .001" oversized rings. It's not the best solution, but it's the easiest and cheapest.
I like the truck, I love that body style! It'd be awesome retrofitted with a newer engine in it.
Rolling_Eudaimonia
New York State
Well if it is a GMC it is a gas powered truck for sure. And it is not the M35A... is not part of the M44series trucks. Instead it is a M211 truck. You'll need to find all the manuals for that truck not the M44 series trucks. I don't know where to find those off hand try Olivedrab.com they might have resources for you. The trucks are simple but you will need wiring diagrams and other stuff like that.
