My new M35A1 project
scooter01922
42
Newbury, MA
Here you guys go, i finally sealed the deal so now i can post this up. Not sure what year as i didn't actually look while i was there. I need to thank boatcarpenter on this one as without him i would never have found this truck, gotten such a great deal or have gotten nearly as much done. We met up this past friday and spent the afternoon turning back the hands of time. Had to forcibly remove it from its resting spot with a large tractor, it did take some doing but it moved. Surprisigly enough all but the rearmost 2 tires on the pass side are inflated still. New fuel filters, new batts, drained 20 gal of something that resembled diesel from the tank. Still another 5 or so gal in there but i ran out of buckets. Will be pulling the drain and giving it a flush the next work day. Pulled the in tank pump and cleaned it up a bit as well as setting it a few inches off the tank bottom so hopefully i can avoid sucking too much of the crud that will no doubt still be in there. At least untill the truck gets home and i can drop the tank for a propper scrubbing. Jumpered across the aftermarket ignition and got power to the important stuff, starter and fuel pump at least, haven't checked anything else yet. The in tank sounded pretty decent after the cleaning, sounded a little odd before it. Hit the foot starter button with the stop cable pulled just to see if it worked and the truck cranked like a dream. Would't guess it had sat more than 5 min rather than the 10 years it has prob been since it moved or started. Still need to change the oil, reinstall the drivers door,and fix the brakes. No surprise the petal went to the floor. Strongly considering going to DOT 3 as the system will need to be completely bled anyway. Have a look at the pics. How about that primary filter?? Looks like a bunch of brass discs stacked together and compressed when you tourque the bolt that holt the cannister. All i know is that the primary was full of crud and the secondarys were pretty clean so it got cleaned with a toothbrush and put back in. The NAPA replacement would not fit as i would need a larger washer on the bolt.
scooter01922
42
Newbury, MA
More pics, have a look at these tires :) The plow it comes with, and the parts truck that me and BC will be parting out. Has a LD 465 and a really od tranny in the parts truck, says made in england ( see pic) And finally check out the truck full of green goodness i saw while driving the 2 hours to the truck.
doghead
4 Star General /Moderator
1,172
TMC transmissions are just the original Spicer rebuilt by TMC in England. Not that uncommon. Do a search here and you'll see!
Great score on the trucks!
area52
San Bernardino CA
Every time I read or hear about the Hypercycle engine, I always think of some cartoon character riding a motorcycle and chasing bad guys. QUICK TO THE HYPERCYLCE ROBIN!!
looks like quite a project, good luck!
scooter01922
42
Newbury, MA
Thanks DH, wasn't sure but its a moot point anyway. That tranny in the parts truck is FUBAR. The top plate looks to have been off it for a loooong time, full of leaves and crud. These things really do multiply. I just had to have it. Will be brought back to life and used to do a little personal plowing, nothing tough. Tough part is getting it home the 114 miles to my house.
NDT
6,144
Camp Wood/LC, TX
What a find!! Does the engine have a "Hypercycle" name plate on the valve cover as well? That engine tends to be a bit smoky, gives the truck even more character . . .
73m819
319
gainesville, ga.
the foot starter and the fuel filter sound like it was a gasser at one time
jatonka
57
Ephratah, New York
Foot starter was standard on the original multifuel Hypercycle trucks, the fuel filter is similar to those on M37s and other MVs back a ways in time. They were effective and able to be taken apart and cleaned as good as new. But, very time consuming, I've done it.
Scooter, show the guys a picture of that turbo, should impress some people.
Smoke.............???.................... Like no other engine out there!!!!!!!!!! Like a destroyer laying a smoke screen in WWII. JT out
