Those Aren't Filters, These Are Filters!
USMC6062
St Augustine, FL
Good looking and 5 micron filters. They do not appear to be anti-drain.
How do they perform?
I just put them on today, so we will see. I don't think they make an anti-drainback filter this size, but if they do it would have saved me some work. I made my own valve in the adapter to keep the filters full, so I can use any comercial filter and not worry about if it is anti-drainback or not. I let it sit a couple hours and I still got instant oil pressue, but I'm gonna let it sit for a week or two and see how it does.
cranetruck
92
Meadows of Dan, Virginia
If they are in fact 5 micron filters, they will need to be changed often. Monitor the pressure drop across them so that you don't end up with a bypass valve opening and no filtration at all. For fine filtering, use a bypass filter and keep the full flow ones at 25 microns....
dabtl
Denton, Texas
It will be interesting to see how they work out. Bjorn may well be right in suggesting a by-pass with this 5 micron filter. I would hate to lose filtering for a period of time!
But, we shall see.
USMC6062
St Augustine, FL
How much more oil did you need?
Well I was wondering myself, but like an idiot when I drained the oil I only got maybe 3 to 3.5 gallon out. I just checked the oil last time I drove it and it was full. I know it should hold 5.5 gallons, but I couldn't figure out why I didn't fill up the 5 gallon can I was draining it into. I was a little too excited to see if my new filter setup worked, so instead of finding out where the other 2 gallons went to, I filled it back up with new oil, but ended up over filling it. After I ran it for a minute, I started looking at my other truck and spare engine I have thinking my truck has the wrong dipstick or something, but all three were the same. So I came inside and researched on here, but everyone said 22qts like it says on the dash. Then I saw it, "remember there are 2 drain plugs", doh! Needless to say I drained some out of the other drain plug and got it to the proper level, but now my new oil is already black from getting mixed up a little. I know how the oil pan is made it would have two drain plugs, but I didn't even think about it. It didn't help that this was the first time I changed the oil on either of my deuces, but I guess I won't forget now. So through all the over filling and draining, I have no idea, but I would guess maybe an extra gallon.
USMC6062
St Augustine, FL
These filters have all the same specs as the 1792XD filter that ODIron's kit uses and I know his was tested, so this can't be any worse.
bottleworks
Central NC
I think the OD Iron kits are bypass filters not primary.
No he also sells a full flow remote filter system using the Wix 1792XD filter.
USMC6062, Nice work. I bet those filters will handle just fine. They should have enough contaminant capacity to continue filtering @ spec for full oil change intervals.
USMC6062
St Augustine, FL
I haven't decided yet if I want to try and build these to sell or not. If I decide not to I will share everything I got, but for now I'm not gonna tell all. I have to get the machining done more resonable. I did these on my lathe, which is a 1943 Leblond Regal, and it took around 20 to 30 hours to make both of them. I don't think anyone in there right mind would pay me to make them a set. If I can get them done on a CNC machine for a decent price, I might try selling them. Of course the first one that someone buys will see how they're done and the secret will be out anyways.
garp
black hawk sd
A man after my own heart for sure! I work for the local CAT dealer as a field mechanic. I wonder on your choice of filter though. The 1R1807 has the same rating, is atleast a 3rd smaller so it wouldnt be so tight. To my knowledge Cat dosnt offer an anti-drainback filter, all of em hang down. As far as capacity, no problem there. You wont have any problem with plugging, I dont think people realize how much crud you have to put into the filer to plug it. Keep us in the loop on your findings
