When I bought the second deuce in July, it had a few problems. The one that made me really crazy was the intermittent starting. Run it till it got hot and park. Shut it off. Then it kind of wanted to cool completely to start. Sometimes it would start hot if you held the starter button down and moved the on/off lever around. Sometimes it would not.
I changed the on/off switch out. No solution. I changed the starter button out. No solution. Given power the starter never failed to turn. Made me crazy. I got out the wiring diagram, discovered the starter relay hiding up under the passenger side of the engine and the more I thought about it the more I became convinced that was where the problem lay.
But, it looked to be a pain to change out. I asked a few questions on this board, they got answered quickly.
So, I obtained a NOS relay and started changing it out yesterday. Took a couple of hours, waiting on paint to dry for the most part.
I have heated the truck up twice today and it starts every time. Great feeling and a sense of accomplishment. But, I would have spent much longer on it had it not been for the help I received here. Thanks to all of you who offered advice.
