nitrous oxide as a fuel catalystexactly what do you mean by "nitro system"? do you mean nitrous oxide as a fuel catalyst or nitro-menthanol as a fuel source?
nitrous in a diesel is only good for two things:nitrous oxide as a fuel catalyst
The head bolts stretch even with stock turbos. With a big cylinder pressure boost Im sure your going to have some problems. I understand turning up the fuel some, making sure the valves are adjust just right, larger air cleaners and all the new type of filters, adjusting the timing some.. but all this talk every day about a "super Multi hot rod" man this engine just not going to handle modern day diesel spanking.
If your going "juice the deuce" just be sure to get multiple angles atleast 1 high speed camera and have a camera in the cab with you. I want to see this.
If your going "juice the deuce" just be sure to get multiple angles at least 1 high speed camera and have a camera in the cab with you. I want to see this.
opcorn:
Don't forget your face shield and hearing protection.Please try it. On your truck.Idea, how abowt a nitro system?![]()
I know what you're saying about the mutifuel not being able to handle it but it's a "gearhead's" nature to try and get more HP out of any engine. If the multifuel turned out 1,000hp stock there would be people on here trying to get 2,000hp out of itbut all this talk every day about a "super Multi hot rod" man this engine just not going to handle modern day diesel spanking.
