2009 vin info thread
CARNAC
The Envelope Please.
619
Corpus Christi, TX
Hope you can help me, CARNAC. I don't have much info. M35A2.
VIN# 012531259
NSN 2320000771616
Unit Ident Code:
WAZ1C0 Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 NSN:
2320000771616 Serial Number:
12531259 Registration Number:
4K6177 Year of Mfg:
1967 Manufacturer:
65909 Usage Miles: 747
Info Sep 2005
OPCOM
27
Dallas, Texas
M35A2
dumb question, but, I know where the VIN is. I't on the dataplate and also stamed on the frame, right? But where is the registration #?
CARNAC
619
Corpus Christi, TX
It all depends on the manufacturer and if a dataplate was replaced. Some had the registration number stamped on the data plate and sometimes in conjunction with the vin.
Others didn't have it stamped.
Regardless, units as a routine stenciled the registration number inside the door. Not sure if/where it says to do this in the regulation. For me, it always made it easy to open up the door and read it off when refueling vehicles since you had to provide the registration number to the refueling point.
CARNAC
619
Corpus Christi, TX
Howdy,
M35A2 Drop Side from MCLB Barstow 4-09
Stock No. 23209260873
Identification No. NKO4DS 054011214
Contract No. DAAEO670C0001
Bumper Info. 63RC D69 693QM
164CSG QM34
:roll:
Organization:421ST QUARTERMASTER DETACHMENT Location:LOS ALAMI
CALIFORNIA
Nomenclature:
M35A2C NSN:
2320009260873 Serial Number:
54011214 Registration Number:
NK04DS Year of Mfg:
1972 Manufacturer:
65909 Contract Number:
PO Number:Usage Miles: 10320
Info Sep 04
CARNAC
619
Corpus Christi, TX
a. Serial Number - 052525284
b. Registration Number- NK007N72
c. NSN - 23200771616
d. Location - Kirkland AFB, Albuquerque, NM
e. Bumper numbers - none
Thanks,
Warthog
Organization:907TH MED CO DENTAL SERVICES Location:ALBUQUERQ
NEW MEXICO
Nomenclature:
M35A2 NSN:
52525284 Registration Number:
NK007N Year of Mfg:
1972
Info Sep 05
CARNAC
619
Corpus Christi, TX
SF 97 from Govt. liquidators was wrong...?
Frane number: 032510552
I.D. number off sata plate: 35180168032510552
Mfg. By (from ID data plate) Kaiser Jeep Corp
Contract number (on ID plate) DAAE0668C0007
Marking inside of doors: NKODUW
MWO tag applied 10APR90
92320200351
Scrapped paint off bumpers
Driver side bumper, Found B401
Rear passenger bumperette B161
Thank you again Great Carnac
Organization:578TH EN BN CO B HVY REAR Location:LONG BEACH
CALIFORNIA
Nomenclature:
M35A2C W/W NSN:
2320009260875 Serial Number:
32510552 Registration Number:
NK0DUW Usage Miles: 31541
Info Sep 04
CARNAC
619
Corpus Christi, TX
04J48970
052513722
DAAE 0670C0001
MWO APPLIED 9-2320-200-35-1 DATE 9 3 0 6
Front Bumper No. CS551
Rear No. 551
8 stenciled on RH door.
Purchased from an individual in So. Boston VA who got the truck surplus in Richmond.
My first M35, and thanks for the help,
Greyson
Organization:131ST EN CO CBT SPT REAR Location:COLCHESTE
VERMONT
Nomenclature:
M35A2 NSN:
52513722 Registration Number:
4J48970 Year of Mfg:
1970 Manufacturer:
65909 Usage Miles: 9160
Info Sep 08
CARNAC
619
Corpus Christi, TX
truck picked up in Sparta, Wi May 2009. Am General m35a2,softop,no winch .stock# 2320000771616 id#082510177 contract#daaeo781c5307 thanks a ton for your help. :grin:
Organization:107TH MAINTENANCE CO Location:FT MCCOY
WISCONSIN
Nomenclature:
M35A2 NSN:
82510177 Year of Mfg:
1981 Usage Miles: 39030
Info May 06
CARNAC
619
Corpus Christi, TX
a.) VIN: C124-13372
b.) REG NO: none
c.) NSN: 2320-00-050-8984
d.) From Redstone Arsenal, Al
e.) Bumper # Pass side: 731CSSB Drivers side: 1670 T 209
Curious as to why there was no registration number.
Thanks again CARNAC.
Organization:311TH QUARTERMASTER CO Location:AGUADILLA
PUERTO RICO
Nomenclature:
TRUCK TRACTOR 5-TON Model:
M818 NSN:
2320000508984 Serial Number:
C12413372 Registration Number:
Usage Miles: 575
Info Apr 02
but here is the same truck prior to remfg. Probably assumed it would have the same reg # but it should have had a new one assigned. One of many govt f ups.
PUERTO RICO
Nomenclature:
M818 W/W NSN:
2320000508978 Serial Number:
5A05971 Year of Mfg:
1971 Usage Miles: 575
Info Jun 99
Sevo
Roswell, NM
Carnac,
Here are 2 of the deuces I just recovered. I hope you have some info..
First one is a old gasser deuce but has a brand new multi in it.
Vin: 4A4924
Reg: None
NSN: None
From Ft. Jackson
Bumper #:
Passenger side: HQ-73
Drivers Side: 218BDE-1
Second One
Vin: 4k6678
Reg: none
NSN: 2320-077-1616
From Fort Jackson
Bumper: None
rebel_raider
El Dorado, AR
Pardon my ignorance CARNAC, but does a UIC mean that the unit was disbanded?
Also, my truck has been out of the military for 10 years at least. How did you quote info from 2005? Again, pardon my ignorance.
CARNAC
619
Corpus Christi, TX
Not only disbanded but the unit information has been removed from the database.
In 2005 a data dump was conducted to remove obsolete info. Not sure what the criteria was for this dump considering some info is still around from prior to that time. The date given for the info is the last time the record was modified.
Above all else, it is because I am CARNAC and I can feel the green vibs from your truck.
CARNAC
619
Corpus Christi, TX
Carnac,
Vin: 4A4924
Reg: None
NSN: None
From Ft. Jackson
Bumper #:
Second One
Vin: 4k6678
Reg: none
NSN: 2320-077-1616
From Fort Jackson
Bumper: None
Both of the numbers you gave for vin's are actually registration numbers. Sure hope you haven't registered them in your state or you will need to have everything amended.
Organization:218TH INFANTRY BDE HHC Location:NEWBERRY
SOUTH CAROLINA Nomenclature:
M35 NSN:
2320008358463 Serial Number:
M42506 Registration Number:
4A4924 Year of Mfg:
1957 Manufacturer:
03944
Info Nov 1986
Prior to this date it was with the 1 Bn 178th FA of the SC ARNG.
Organization:SVC BTRY, 1ST BN, 178TH FIELD ARTILLERY REGIMENT Location:HEMINGWAY
M35A2 NSN:
12531949 Registration Number:
4K6678 Year of Mfg:
1967 Manufacturer:
65909 Usage Miles: 36137
Info Dec 07
Prior to that it was with the 4th Bn 118th IN in Union, SC
Sevo
Roswell, NM
Carnac,
your right, I pulled that number off the data plate and not off the frame. Luckily I have not registered it yet. Thanks for the heads up
Thank you for the information. I really appreciate you looking these up
thank you.
Sevo
Roswell, NM
Carnac,
Ok I found the vin for the 67 deuce, but the 57 deuce's vin is gone, there is nothing on the frame near the steering column. Would you happen to have any info on that?
Thank you again for your time and help
Sevo
Roswell, NM
Never mind I see you provided me with that information already
Serial Number:
M42506
this is also considered the vin Correct?
Sevo
Roswell, NM
On the old gassers, you need to check the frame on the right side not the drivers side.
Thank you for the help Carnac. I will take a look when I get home.
Ferro, good call on the year bro! You were right on... Looks like she really was a gasser turned multi
