hemmit rims from columbus problems mounting
frostvair
Banned
13
ohio
Did anyone put the rims on a truck yet? I tried to put them on an 818 and had a few issues with the valve stems and also the stud length. I will have to change studs for another 1" length to make them work. Am I missing something?:?::)
Westech
CPL
6,104
211
cow farts, Wisconsin
no... but the thing to do is use the rear lug nuts. Install the rear long nuts and then the rim and then the large outer nut. that will get the rim on the hub. The valve stem will be a problem.
area52
San Bernardino CA
There are a few posts on here about the longer studs for the front. One way is to install "budcaps" If you search for that, you should find the posts I am talking about.
coeder
Ohio
I need a better explanation. I have been asked that question for days now. I am not in on this info or something. That is definitely not my name. I would like someone to PM me and fill me atleast for all of the time I've spent responding to this question!:!::-D
frostvair
Banned
13
ohio
Coeder, you may understand, but I am the one under fire for some reason. It must be an OHIO thing. I read a bit on google and get the situation. It is nice to be informed.:-D
doghead
4 Star General /Moderator
1,193
Just to be clear, is that a yes or a no(are you Darrell Braun)?
m16ty
227
Dickson,TN
Frost, All Doghead asked was if you were Darrel. If you are not don't worry about it :-D. No harm on foul.
Doghead, If darrel does show up here under another username I don't expect him to admit it :wink:.
doghead
1,193
Thanks, sorry if you were confused or offended. The best way to get a clear answer, is to ask a clear question.:wink:
