That M52 job looks real nice. What is the propane for? Do you have more pics? I'm really wanting an 818 but I'm interested in all info..
Advantages:
More room in the box than the S280 shelter.
Wide hatch in the 109 box. ATV will fit in.
250HP Cummins NHC250 engine - every shop knows how to work on it, in case I need big help.
M818 itself is fairly light in weight at 19,765 LBs vs M35A2 13,500 LBs
M818 payload is 15,000 LBs. vs M35 10,000 LBs
M109 body weighs what 3000 LBs? so would be 22,765 LBs ve My deuce's 20,000 LBs as-fitted weight. Note th HP/Lb ratio.
63MPH with 53" tires vs deuce 59MPH with 11.00x20's. make it possible to cruise at 60 all day..
Disadvantages:
Taller height with the planned 53" tires
- (Vinny's was 11FT 3" with (assumed) 16.00x20 tires)
Higher fuel consumption than M35
2,765 Lbs heavier
Where to put the spare?
- Too big to fit between the cab and box unless the box can be moved back. The "wheelwells" are cosmetic far as I can tell having looked an a 109 the other day.
- - If this were done, the spare carrier might have to be modded - and the toolbox is going to have to go.
- Could be put in the box, but that would take up lots of room.
Now that we know the 818/109 truck can be done, (Thanks Vinny) and more info has surfaced, there are enough details to mention:
- One constraint I face is time because the plan was to travel to 54REO's place this fall, and he would help me do it. He's got alot of the right tools and the right skills also, being a millwright so it won't be like me trying to do a hack job at home. I can take off only 14 consecutive days. 2 days minimum travel each way. distance 1000 miles so more like 3 days. This might resolve itself.
The pieces:
- Today, I do not have an 818 truck or 109 body. I would prefer them with as little rust as possible, especially the 109 body. I'm used to some rust on he trucks, all these trucks have it and I am not building a showpiece. It could end up as one though if the parts are nice enough. This might resolve itself.
M109 bodies:
- 109 bodies are damaged badly by rust because they have wood in the walls and can rot. This can be detected around the edges of the walls at floor level. Even if someone has cleaned off the rust to improve the appearance (haha and sometimes to ask more $$), the evidence is there if one knows what to look for.
Mounting:
- 7/8" U-bolts can be used to hold the 109 body.
Lift gates:
- While it might be a relatively simple task to strip off the 818's 5th wheel and place a 109 box on it, I really want to have a lift gate. I'm studying that..
- 34" frame width (for a lift gate - I really need one since one reason for the 109 box is so the ATV will fit inside and I won't need a trailer)
- -About the lift gate, the M820A2's gate and hardware incl PTO might be too complex and space-consuming, maybe overkill, definitely and hard to find+costly. It has not only a PTO driven pump, but a shore powered AC motor. Either can be used. I would not need the motor, and I have to keep in mind definite space limitations because the 818 is alot shorter than the M820A2. The gate assy and aux equipment is also very heavy.
- -A 24V or even 12V pump-operated gate would be best. I need only 1000 LBS capacity (820A2's gate holds 3000 lbs). If a smallish gate is too short, it can be lengthened or extensions added for the wheelbase of the ATV.
- -There are two kinds of gates I'm aware of.
- - - One folds up under the back-end of the truck bed/body.
- - - One folds up flat against the back of the body (820A2 style)
- - - - Of these, there is a kind with cables and pulleys in posts on each side of the gate on the back of the body (fit like on rental trucks), and a kind with no pulleys and cables (fit like on M820A2).
So this is where things stand at the moment. 818's go for low prices like <2K on GL especially when there are several in the sale. Therefore, maybe I can buy one that runs and drives correctly at a good price, even if someone is passing one along to me that is excess to their needs. I really cannot pay retail for one. I also have room at home for only one truck so that is another thing but it might resolve itself in some way. 109 bodies - they can be had for cheap enough because people take them off to replace with beds or cranes or what have you. I think this project could be very interesting and also would be well documented. It would be the perfect use of time and materials on a road trip.
Pictures are of Vinny's 818+109 and of my M35+S280. Notice the height. It's hard to tell but the M35 with S280 is about the same height because there's the bed, then there's integral skids under the shelter as well as the insulated shelter flooring itself, adding maybe 8-9" to the height over an M109.
