- 1,998
- 31
- 48
Does anyone know if the trailers offered for bid have wood or steel decks? I want one but really want wood as I live by the coast.
Many Thanks in advance!!
I guess by that is he is wanting wood because of the rust but would it really make a difference? After all the rest of it is going to be metal. Waynebut really want wood as I live by the coast
That's the one I was calling the 5ton...smallest one I'm aware of. Could be wrong. The bolster I mean.
Actually I've had more than one carpenter tell me outdoor items will last longer if not painted, by not painting it allows the wood to dry out when it get wet. And if the wood is not complete dry and you do paint, that just traps the moisture inside and it rots from the inside out.In their infinite wisdom the military decided that painting the decks was not authorized
Many thanks for the kickbacks. I was looking for a wood deck as it ususally lasts longer. I had a friend that got a trailer from a state surplus sale and it lasted only 3 years before rusting through and had to R/R it with wood. I did not know if all of the trailers were all metal.
As far as sealing a wood trailer, you can use Thompsons water seal on it every 4 years, only treat the topside and let the sides and bottom breath. Has lasted me 20+ years on 1 trailer I have. BTW, keep all leaves and such off the wood and it will last longer..
Again, Thanks!
