- 4,044
- 131
- 63
- Ponchatoula LA
taylor ill throw them on the wagon so to speak
you can just use a flat plate. and drill the 8 holes in it.I am removing a winch from a m35a2. I need an inspection plate for the trans. so, I can remove the PTO. Also, I have 2 deuces that I want to make the middle axle a dummy axle for highway use. Does anyone have either some spare/ broken axles that I can cut? Or, spare front axle hubs? I believe since they have an open carrier I should only have to remove one axle per diff.. I will need two.
I'll take one for my spare! Just give it to Tim to bring back. What about the valve stem?Does anybody need any HEMMT rims?????
I will only bring what is ordered.
75.00 each with lug nuts and gasket.
